i have for sale rb26 single high rise stainless turbo manifold with a 50mm wastegate and screamer pipe with a trust greddy t88-34d turbo.
this set up has made over 600hp at wheels on a small set up. has only done dyno km reason for selling not big enough for what i em doin.
pick up only or local meet up sydney.
price $3000
https://www.sau.com.au/forums/topic/298130-rb26-single-turbo-kit-t88/
Pick up only :) hmm would think about it if could be posted, curious now this was on a built rb26 wen was it making boost bye? wat rear housing? is it good street application?
hey mate the rear housing is a 24g which i think means 24cm housing but yer street wise it was fun on my car it had full boost bye 4000 started spooling at 3600 but just kept boosting never dropped off. the work i did to my engine was just forges and cams nothin big just had a good tune. i would consider posting at buyers cost but i would hae rathered pick up just been a heavey item and stuff. but if need be i will post. cheers
Hey buddy wat else will be required with this set up, i have a apexi power fc wit z32 afm an wat not is that still fine? an this doesn't come with a gasket set either or water oil lines does it?
it does come with oil lines as it is only oil cooled turbo. that computer should be fine but i hope u got bigger injectors and fuel pump. u will have to get the exhaust to suite andthe intercooler pipe should be a close fit to it but may need some adjustment. but sori doesnt come with gaskets as they broke when i took them off car but they can be bought very easy.
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
