I know it's a bit of a simple question but i dont know the answer so i thought I'd ask anyway. I have a no name pod and am pretty sure it's pretty crap quality, i was just wondering how much difference i would notice with a more expensive better quality one.. Like if the material on them makes the flow that much better to spend 100-200 on a good pod.
https://www.sau.com.au/forums/topic/298147-pod-qualities/
Much of a muchness if you are running a standardish setup. You'd be hard pressed to notice a difference.
As long as its not a HKS "mushroom", those things are shithouse and foam breaks off too easy into the intake.
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4960924
i tried a monza one from autobarn many moons ago
it was ass, it killed all the throttle response
i dont know how, but i did
with the monza one fitted ,there was noticable lag from the time you open the throttle to the time the engine got positive power
took it back, changed to a k&N one and it was back to new again
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4960981
I was about to mention that magazine test - not sure where you can buy 3A Racing filters from though, but at only 30 bucks vs over 100 lol, thats pretty compelling.
You can buy them from Dr Drift
I have a 3A pod. back to back V.s K&N, I honestly couldnt really notice. The 3A is a lot cheaper tho!
Can you confirm if they are washable and re-usable?
I believe that they are a dry type cotton element, yes? Wouldn't they require oil if they were re-usable?
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4962805
well yes I have washed it before. Hot soapy water, blow it out with the compressor and let it dry out properly in the sun also. I do it maybe every 3-6 months. No I do NOT oil it
actually I have had the pod for over 2 years and its still looking good/performing well.
and something I just remembered, a mate of mine used to have a JZA80 TT supra which had a ARC induction box, for science we fitted a 3A one day and the difference was amazing. Sharper throttle response and seemed to breath better full stop. considering the ARC sells for maybe 20 times more than a 3A pod, they are definatly good value.
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4963573
thats a pretty tall call to say that it's better than an ARC induction box.
The Blitz LM filter I had previously seemed to let quite a bit of dust through :S so changed it to an Apexi Power Intake (which incidentally im not sure on how to clean out)
You got the APexi Pod?
Just soak it in K&N Air Filter cleaner, let it soak in for 10 mins then hose off and then let it sit and dry in the sun.
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4963796
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4963799
I've tried many pod filters K&N, Blitz LM etc but im currently using a Apexi one. But the 3A is a bang for your buck how its been dyno proven with very good flow and very good filteration. Heres some pics of the past when i owned my skyline with the podys... Didnt really feel a diffrence but yeh.
Edited by geraus
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4964293
we sell the 3a Racing ones at Autobarn in penrith .. actually i just recieved 3 yesterday .. they also look really good for how much they are .. And in tests actually are better then the K+N and a bonus because they dont have shit oil that stuffs around with ur hotwire AFM! ..
They are like $48 from memory compared to $99 K+N ones .
And i sell pod filters everyday
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4964678
I have a hks one sitting here, was never on the car because i just found it in the boot lol. Shit pod and would never use it. Got a 3A racing one. Been using it for 2 years and its still perfect, got it from Shan (funkymonkey) when he got some for a few of us sau guys.
https://www.sau.com.au/forums/topic/298147-pod-qualities/#findComment-4964909
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
