Hi guys,
Thought I'd change pads on my front brakes. Set up is 8 piston unassisted. Outside pads went in fine, however inside pair needed to be helped with a rubber mallet as the pistons would not retract sufficiently. Consequently wheel now does not rotate. Would draining brake fluid and releasing pressure enabling pistons to retract to release pads off disc. Any help appreciated!
https://www.sau.com.au/forums/topic/298156-pads-changed-wheel-stuck/
well...is the disc exactly in the centre between the 2 sides of the caliper? even 1/2mm can make a big difference, so most likely either the wrong offset disc or inaccurate caliper brackets. The good news is, inside too tight can be corrected using shims or washers between the hub and the caliper to space the caliper inwards a little. The G4/D2/Ksport 8 piston brake kits come with shims for this exact purpose because they know not to trust the factory's "tolerances"
2nd....some pads are simply bigger than others new. You can always grid a little off.
3rd....if it is actually a piston not retracting ie if you pull the caliper off and you can't get the piston to sit flush....then you have a seized piston and this will stuff your braking performance. In this case remove the caliper and get it rebuilt, may be expensive if the brake piston or bore are damaged.
Ok thanks for info, so you suggest i remove caliper? How do I release the pads hold on disc i.e tight as.
That's where i would start, you need the pads back out to have a good look. Wheel back off, undo the 2 big bolts that hold the caliper onto the hub. If it does not come free easily lever it off the disc.
then take the pads back out, and have a good look at the caliper pistons (be sure not to let the caliper dangle on the brakeline - support it).
can you push the pistons back so they are level with the caliper (or at least even on both sides)? If not get the caliper rebuilt (or a new one if it is a G4/D2/Ksport one lol)
if so push them right back, and put the caliper back on the disc.
is the disc exactly in the centre of the caliper? If not, do you have the correct offset disc? O if it is close to centred you can use a washer or shim to space the caliper inwards a little - put the washer between the hub and the caliper.
Thanks for the info!
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
