Hey Guys,
For sale is an RB20DET out of a 92 R32 i am now doing a 25 so no need for this anymore...
what the engine has:
-Head completely redone by thornleigh cylinder heads (decked, cams linished, cleaned, new valve seals, valve seat regrind etc)
-Cometic Metal Head Gasket
-Mahle pistons rings
-ACL Race Series Big End/Main Bearings
-Honed etc
-Block tested
-Crank Linished
-GTR Coil Packs
-440cc injectors (just been cleaned and tested)
-Gates Racing Timing Belt
Will sell with stock turbo and ecu for $1500
this setup on a run in tune and a KKR430 turbo made 212kw at 8psi.
pm me or msg me on 0421 308 872
will post pics when engine is out of car
https://www.sau.com.au/forums/topic/298162-built-rb20det-for-sale/
bump.
also to mention it comes with loom and mines ecu. will also throw in gearbox but no clutch/flywheel.
still $1500...you could hardly get a std motor and box for this let alone ecu and injectors etc so wanna get it quick
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
