Hello guys,
Still wrecking white R32 GTR, have sold most bits but have still got a lot of small stuff left. Will put engine parts on the bottom of the list.
12 coil packs, 6 of them were from the white gtr, ran fine but was only running std boost. 6 are from my grey gtr, worked well but started breaking down over 20 psi. $50 for the whole lot
Steering rack with tie rod ends, $50
Clutch slave cylinder $20
Clutch master cylinder $30
Brake Booster $30
Power steering resevoir $10
AC condensor, radiator sorta thing $30
Factory rubber intercoller hoses x 3 $60
AC fan $20
Front wheel speed sensors $50
Front right hand hub with driveshaft, front left hand hub with upper and lower arms and driveshaft $100 pair
Passenger seat, just been professionally cleaned $150
LH door, white, missing the latch and central locking piece, paint bit rough but door good $100
Bare steering column $20
Taillights, no surrounds $30 pair
Drivers side headlight, has had hole cut in bottom of headlight, dont know why but it doesnt seem to affect its operation. Could plastic weld a piece in there if you wanted it to look mickey mouse, even though you cannot see it once it is mounted in car $30
Starter motor $30
Rear cradle with brakes, diff and suspension arms, missing hicas and the hicas arms $500
Front crossmember $80
Gearbox, has done 500km on a full $1500 rebuild, the transfer case had done 2000km on a full $1000 rebuild. Only used synthetic gear oil. pretty much brand new $1500
Pair of HKS 2530's, pretty much brand new,were fully rebuilt after i blew engine, cost $2500 to repair the pair of them. Once rebuilt i put them on another engine and the other engine and i couldnt get other engine to run right so i removed them again. Selling for cost of rebuild $2500
Reco head, head has the same story as the turbos, blew engine, got new head built, Has $1400 worth of stainless steel valves in it, type B cams, heavier valve springs, all reshimmed etc by engine reconditioner. Sell for $2200
Sump with diff etc, diff good but needs checking, i havent had in a car for a long time. $50
Gmax 6 spoke white wheels, 17x8 with +32 offset, no tires $400
Have got heaps of other little engine and car parts, just ask.
Thanks,
Michael
https://www.sau.com.au/forums/topic/298184-for-sale-wrecking-r32-gtr/
Hi Michael, I do still want the coil packs and sump and diff, plus Front right hand hub with driveshaft, front left hand hub with upper and lower arms and driveshaft , and need to catch up witjh you and have a chat, cheers Damo
Edited by madaz R33
Hmmm, i have had the coil packs and the sump in my boot of the statesman for about 3 months now. Have tried to call you and have sent you text messages and havent had any answer back. So i presumed you didnt want them anymore.
Also,
Why do you need the hubs with driveshafts? There was nothing wrong with the ones i sold you on the car unless you bent the ones on your white GTR?
Coil packs are pretty much sold, you can still have the sump and diff and some1 is after the driveshafts and hubs.
You better call me
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
