Well I joined up a few months ago but I never got around to posting up on here.
Well my name is David and I live in Devonport in tassie and this is my R31
When i first go it
RB25det with broken piston ring
cut springs
stuffed lsd
What I've done so far
Engine
RB25/RB30
RB25det s1 head
NA RB30 bottom end
Greedy style plenum
Stanless high mount
38mm external gate with 6psi spring
T04z with .86 rear housing now going gt3540 with .82 exhaust housing for quicker spooling
intercooler
custom short piping, 2 1/2 inch hot side and 3 inch cold side
3 inch exhaust
50mm alloy radiator
Boosh 044 fuel pump
Surge tank
R33 intank pump feeding surge tank
Driveline
RB25det gearbox
Extrame cushin button clutch
custom on peace 3inch 3mm thick tail shaft
3.89 Weldy now got 3.7
Suspention/Brakes
Front: R34 4potters on 310mm rotors
whiteline springs and kyb shoocks
front nolithain bush kit
Just scored a jap inport steering rack wich are a quicker ratio
Rear: r33 gtst front struts with a coil cut off them on modifyed mounts
Full nolathain rear bush kit
Interior
Both buckets seats installed now
Timex gauges- Tacho/speedo, air/fuel, boost, oil pressure, water temp
Speco gauges- fuel leval, volts
sound deading stripped from the front of the front seats back
stripped boot
Mods in the near future
remaped rb20 ecu and z32 air flow meater
turbosmart boostcontrolar-got now just gota install
s13 extra lock spacers for inport 31 rack
nolithain rack mount bushes
rose jointed caster arms
brass streering sfaft joint to replace shit ruber one
The car
Old set up low mount T3T4
Started moving wires, staring to work out new turbo set up, New taillights and bushes and a few other bits
https://www.sau.com.au/forums/topic/298187-hi-im-new/
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
