Guys i have been looking for a car since early this year and been comparing EVO IX, WRX STI 06 & Skyline R34 V specs. I like to find out what common problems do R34 GTRs have so i can get a better understanding when I’m making my final decision. I know most problems and issues on Sti & Evos but nothing on R34 GTR’s so I would really appreciate if you could help me out here! :D
https://www.sau.com.au/forums/topic/298194-common-problems-with-r34-gtr/
No problems really to speak of in my case...
In 3 years of ownership, I've only had to replace a set of coilpacks with Splitfires, the oil pump with an N1, front rotors replaced with slotted DBAs and before I took ownership I had a rust spot below the bootlid light attended to.
The car gets serviced every 5000Kms and that's it.
I'm looking for one also! I couldn't find much in the way of a "buyers guide" either...
Terry_GT-R34, weren't/aren't you a member of Prelude Australia?
Hehe, yes still am in PA.
Nice bunch of guys (& girls) and no hairdressers afaik lol
Just take your time. make sure whatever you buy is THROUGHLY gone over by a decent mechanic. And check for dodgy accident repairs, some of the cheaper 34 R's have had a decent whack.
Cheers
you have the problem of looking bad-ass when you drive around in it
that is all
I'll be in the market for one in the next 1-2 years as a track cop
edit: LMAO why did the language filter change p-i-g to cop?^^^ :( p-i-gs don't eat donuts
Neck injuries to bystanders cause its such a head turner.
Accidents cause its stops traffic.
...not to mention that some owner had to travel 200km to pick up his car from his service-technician/engine-rebuilder lol
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
