  • Replies 43
Na wont hurt it and it just the bolts and it comes off tho you should mark were it is so it easyer to line up when it gose back on. It take a fair bit of times to file the writing of and get ride of the cast marks out
Well filled some of the writting off and started sanding the caste marks out
Well Im a bit bord so just thought i might throw some pic up of my best mates car up. it not a skyline but it one of the reason I get less of my car done Its a turboed eb 2 s pac with a r32 front bar. Its stripped down for a respray and a little motor work You can imagen the looks we get when both the cars are parked next to each other with the bonets up
Old set up j-pipe, t3t4, standard motor, 11.5:1 fuel reg, 3ich dump to standard to 2 1/2
New set up high mount steam pipe manifold, same reg, t4, meatal head gasket, double valve springs, full 3inch exhaust
wow insane!!! nah i dont have a build thread ey, lol just been collectin the parts n i have just started putting them on, hopen for a 280-300rkw mark, if i was to use e85 or a mixed fuel then prob be aim 300-320rwkw, but i just dont want it to be laggy lol, dont really care bout power as long as it smokes 1st,2nd,3rd hahaah O_o
nice eb btw, always loved the white eb with a fmic !! :woot:
Well finally did some more changed my mine on where the cooler pipping was gonna run and manged to shorten it by about 3inch and yes while it will probably not be noticeable every bit helps. Also drilled and tapped the waste gate line fitting into the turbo, started working out how to mount power steering and my dual stage boost controller. then put fittings in for turbo water line but that's as far as I got before I had to leave it
hahahhaha love that vid man, peels fair hard, cant wait to see wat it does with its new build :cool:
ahhh thats cool dont get into debt over cars lol, lets say this time next month ull be pretty on par to restartin the build ye??
ive been thinkin bout polishn my new turbo housing too, is it as easy as undoin the bolts on the back and take it off?? wont hurt it??
:happy:
f**k your gay red
the car in the back ground looks better
Ok welll Ive been think. Its time for me to sit down and work some stuff out and do this thing once and properly
Basically neat a heap of stuff up
Re run a heap of stuff
Braided water lines, oil lines
New catch can set up
And I will explain once I work a few more things out
Edited by lawler
Looking good Lawler, ill be watching this build with great intrest, im going to start a similar build for my 31 soon so the more info the better :(
BTW that turbo looks mint with the letters/numbers shaved off.
Im sorry to say there wont be any more updates because of cercostance the car is now being stripped
But the motor will live on in a mates 31 coupe and the turbo on my mates eb
Edited by lawler
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
