Hay guys i was just thinkin about intercoolers and stuff for 180sx
and i was reading the techincal intercooler page on www.are.com.au i think
and i wanted to know if any one has had experinece with intercoolers in these cars or if any one has fitted one in?
what power output gains do they get? and are there any brands you would reconmend =)
tell me what ya think guys =)
https://www.sau.com.au/forums/topic/2982-intercoolers-for-180sx/
Hi mate..
This is from performance forums..
These guys have sold so many of their coolers to 180SX owners that they now have a kit including pipes and all.
Every single person that has got one from them has been extremely happy.
It's a pretty long post but it's pretty good cause they have pics and prices and contact details and so on..
Link is below..
180SX intercoolers
Happy reading..
I put in a supra cooler.
I think its from a 1jz, or could be before that. its about 3x bigger than the stock cooler.
I havent boosted yet, cause i wanted to wait for safc and fatter rubber, but next week i will have the rubber, and i just did safc, so its happening soon.
I noticed on stock boost there is less lag, and it holds the pressure more constant, it used to go up and down a bit.
It cost me $350 to buy, it bolts pretty much perfectly in, no cutting or modding bumpers, and it cost only $100 for rubber hosing, bits of exhaust pipe for bends etc.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
