only an r33 gtr wheel from 96 onwards will fit onto a series 2
y would u want to anyway? they are exactly the same design
Hey mate your wrong.
OP. Mate if I get you right, you have a R33 Series 2 wheel and you want to buy a GTR wheel and put it on?
Now is the wheel in your S2 GTST the one with the raised centre?
If they are the same shaped/style wheel, they will swap over without a hitch.
If they are not, theres a little bit more involved, but still doable.. Clarify yourself more and I'll tell you how.
um thats wot i was saying,
a steering wheel from say a 95 r33 will not fit onto a r33 from 96 onwards coz of different airbag clips and u r unable to get the airbag to work. (yes they will physically fit on) but airbag wont work.
i know as i put a r34 gtr wheel onto my 95 r33 and thats wot the problem is. r34 and r33 wheels from 96 onwards have the same airbag sensors and clips.
as to why he wants 2 change wheels, there is no point unless yours is scratched and ripped otherwise they look exactly the same
  • 3 weeks later...
No sorry mate you are incorrect, I have taken my 1995 R33 GTR and fitted a 1997 GTR S3 wheel to it, It can be done? My airbag is also connected and working.
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
