If you want a quality job then, as above, Chris Rogers from Audio Express is your man. Remember that an alarm is only as good as the install.
I'm assuming that the OP means he can't afford the time, or that the car can't be moved without a tow truck or something, otherwise import ownership isn't going to be fun lol.
HaHa Thanks for the replys guys !!
Oh, I will quickly explan what is going on, I purchased a skyline off a dealer. ( I think I got good deal out of it haha)
She is a beauty, and i would like to get alarm installed while the dealer is organising rego.. and etc, getting few other things done on the car as well so I would like someone to go to the dealer's garage. otherwise i have to arrange a transport somehow..
by the way. spoke to Chris this arvo, he no longer does the mobile jobs...
Sounds like he is the bloke to speak to about these things but yeah.. any 1 else?
Another vote for Chris here.
Just wait until you have the car. I think you're crazy for leaving a car you've already purchased at the dealer though. Check things haven't gone missing after the fact.
may not be easy, but I'd make the effort to visit him, you won't regret it!!
he's supported SAUQLD for year and will do a great job for you.
Oh I forgot to mention in my post above...
(Didnt think I would need to after the responce already)
Chris honestly (100%) is second to none...
He will never put less than his best into ever job and I cant say that about many people...
He truely is the best in the biz...
I can pretty much confirm this 100%, I had an A/C Circutboard fry on the day he installed my alarm, even though it was completely unrelated he went out of his way to fix it for me, and in the end we got a new circuitboard for a steal and had it working again.
He could of said, "Hey, not my problem" but no, he helped me out and dedicated a whole day to fixing the problem, I cannot stress how professional and meticulous he is in his work.
If you want a good installation you go to Chris Rogers!
P.S. Chris if you're reading this, the A/C is working perfectly, hasn't skipped a beat, currently at workshop getting Motec M400 fitted and final tune :P
Edited by Parag0n
gary,
ta! I was going to give you a call on that. good to hear that its behaving itself.
KSJ602,
I do dealer work but thats it.(who has the car btw?) in regard to dropping the car off - I do pickup/drop off with customers a fair bit. can do teh same with cars but prefer not to if I can avoid it.
I'm not one to totally strip a car (and I do.) in the middle of someone's front yard and then cop bad weather. the alarm installs I do take on average of 4-5 hours and by the end of it you wont see where I have been.
in regard to doing onsite small stuff (radio fits and the like.) I still do that.
pear,
lost count on how many years I have been a SAU club member. I do know that almost every key event I have donated something.
one quick point - trade plate. (and I do have one specifically for this purpose.)
pear,
sorry mate, typo above - 'year' should have read YEARS!!
and yes, many skyline owners have benefited from your prizes/donations to the club!!!! cheers mate!
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
