hey,
im after a good quality set of injectors and coil packs for my R33 gtst,
its all pretty much stock, just got a atmo BOV, thats about it...
so if anyone could point me in the right direction it would be nice. Oh btw im from perth, so if you know a shop in perth would be handy to, or ill get them off the net :P
cheers
https://www.sau.com.au/forums/topic/298305-coil-packs-injectors/
are you wanting bigger injectors or just replacement stock ones? if going bigger then don't forget you need some sort of aftermarket engine management to run the bigger injectors.
also look online for coil packs. they will be cheaper.
im just after some replacements for my stocks :nyaanyaa: haha yeh im looking on ebay they fairly cheap there. do i have to get certain spark plugs or anything, was looking at splitfires :P sounds nice and sexy to me :) haha
Take it to a workshop in your state who knows what they're doing.
You need an aftermarket ECU to run non-standard injectors (don't even bother with 2nd hand items, again asking for trouble, if the current injectors work just get them ultrasonically cleaned instead), and a tune to match the bigger injectors.
Atmo BOV on a stock ECU is asking for trouble, and could be the problem.
Gap current plugs down to 0.8mm, Check the ignitor ground wire (if it's only misfiring when hot you might need a new ignitor), try a new set of copper plugs (if still misfires gap them down to 0.8mm), then have a look at replacing your coilpacks (check http://www.performance-wise.com/page63.htm for cheaper yellowjacket coils)
good aftermarket ecu would be a Z32 ecu with a nistune board in it. also the best bang for your buck option. will set you back around $1000
as for injectors, i agree with just getting the stock ones cleaned professionally.
as for spark plugs, BCPR6ES would be my recommendation. try new plugs before going new coils. much cheaper and can sometimes solve missfire issues if they are simply caused by worn plugs.
i got new spark plugs, didnt really help, just made my car start to shudder at idel... not sure if its ment to or no, made it stop hunting as much ;) so i guess ill go out and get some coil packs to see whats the go, i brought some injector cleaner to see if thats any good.. if not ill take it to someone to clean them xD
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
