Hi i have a 2000 R34 Non Turbo.
I had a basic service completed last week. I drove it home 150kms without a problem.
But the next day, the engine malfunction light came on and my car is shaking/shuddering.
It has been doing this each time i warm my car up.
I have been told by a few people it could be sparkplugs.
I dont want to drive my car back to mechanic and was wanting peoples opinion on the problem?
Thanks :nyaanyaa:
Mad082 - i will check my coil pack, i assume i will be able to find instuctions how to on a forum...
Moodles2 - thats the problem, im not sure exactly what they did in the service. I asked for a basic service so im assuming it was only the basics, i know they didnt change the sparkplugs as they were long life.
I have taken my car into RACV today to have it tested on the computer and 2 codes came back.
They were: Ignition Primary Code Auto and Transmission Manuel Mode Swith Code
They erased the codes, however it has made no difference to car.
Could it be sparkplugs? Can i please have other opinions?
My engine light would come up every now and again when one of my coil packs was dieing it was hardly noticeable, miss fired for a split second and then when back to normal, gradually getting worse. I got them all replaced and now a few months later it started doing it again constantly so i got new spark plugs but it didn't help at all, so i tried an injector cleaner (even after nissan had checked it and couldn't find a problem with the car) and now its running pretty sweet. Must be some shit petrol around at the moment, iv always used premium fuel so I'm guessing that water has gotten into my petrol tank or into the tanks at the petrol station?
Edited by R34 -_-
  • 1 month later...
I have since had my car tested on a DYNO and have been told it is a the crank angle sensor.
I have to wait until Feb to get one unless i pay $1000 through nissan.
2 questions!!! please help!
1 - does anyone know where in melb/vic i can get a crank angle sensor?
2 - is it an easy job to change the sensor? what needs to be done after changing? (do u need to tune it etc?)
Thank you :blink:
Ring around wreckers to see if you can find one. Theres a link in the Victoria section for wreckers.
You should have the car tuned with a new crank angle sensor installed, preferably on a dyno which will give you both maximum economy and power. If you dont want the expense, just set the base timing with a timing light.
Its very easy to change the crank angle sensor but if you tighten it up in the wrong spot, it could destroy your motor after a few minutes of driving. One millimeter forward or back of where it is could cause detonantion, or pinging.
Who has done the work for you so far?
you would have to have an engine on it's last legs to let go due to a few mins of driving with detonation. plenty of people have driven round for months or even years with the engine pinging it's arse off due to being too lean from blocked fuel filters or dodgy fuel pumps.
So pinging is OK?
You're right it's unlikely to destroy itself immediately. Either is driving on a flat tyre. Both are undesirable and lead to expensive and serious damage.
no i'm not saying it's ok, i'm just saying that it isn't a "OMG my engine is going to blow up and kill me and destroy the world" type of situation. hell, a large amount of pinging goes undetected as it isn't audible inside the cabin. and anyone with a stock ecu (or a nistune) shouldn't be overly concerned as the factory ecu will back off the timing if it hears it, providing the knock sensors are working properly.
  • 1 month later...
Just look on ebay or wherever, it's pretty easy to find splitfire or yellow jacket coil packs to replace your *insert car model here*
Edited by mosquitocoils
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
