Hi i have a 2000 R34 Non Turbo.
I had a basic service completed last week. I drove it home 150kms without a problem.
But the next day, the engine malfunction light came on and my car is shaking/shuddering.
It has been doing this each time i warm my car up.
I have been told by a few people it could be sparkplugs.
I dont want to drive my car back to mechanic and was wanting peoples opinion on the problem?
Thanks :nyaanyaa:
Mad082 - i will check my coil pack, i assume i will be able to find instuctions how to on a forum...
Moodles2 - thats the problem, im not sure exactly what they did in the service. I asked for a basic service so im assuming it was only the basics, i know they didnt change the sparkplugs as they were long life.
I have taken my car into RACV today to have it tested on the computer and 2 codes came back.
They were: Ignition Primary Code Auto and Transmission Manuel Mode Swith Code
They erased the codes, however it has made no difference to car.
Could it be sparkplugs? Can i please have other opinions?
My engine light would come up every now and again when one of my coil packs was dieing it was hardly noticeable, miss fired for a split second and then when back to normal, gradually getting worse. I got them all replaced and now a few months later it started doing it again constantly so i got new spark plugs but it didn't help at all, so i tried an injector cleaner (even after nissan had checked it and couldn't find a problem with the car) and now its running pretty sweet. Must be some shit petrol around at the moment, iv always used premium fuel so I'm guessing that water has gotten into my petrol tank or into the tanks at the petrol station?
Edited by R34 -_-
  • 1 month later...
I have since had my car tested on a DYNO and have been told it is a the crank angle sensor.
I have to wait until Feb to get one unless i pay $1000 through nissan.
2 questions!!! please help!
1 - does anyone know where in melb/vic i can get a crank angle sensor?
2 - is it an easy job to change the sensor? what needs to be done after changing? (do u need to tune it etc?)
Thank you :blink:
Ring around wreckers to see if you can find one. Theres a link in the Victoria section for wreckers.
You should have the car tuned with a new crank angle sensor installed, preferably on a dyno which will give you both maximum economy and power. If you dont want the expense, just set the base timing with a timing light.
Its very easy to change the crank angle sensor but if you tighten it up in the wrong spot, it could destroy your motor after a few minutes of driving. One millimeter forward or back of where it is could cause detonantion, or pinging.
Who has done the work for you so far?
you would have to have an engine on it's last legs to let go due to a few mins of driving with detonation. plenty of people have driven round for months or even years with the engine pinging it's arse off due to being too lean from blocked fuel filters or dodgy fuel pumps.
So pinging is OK?
You're right it's unlikely to destroy itself immediately. Either is driving on a flat tyre. Both are undesirable and lead to expensive and serious damage.
no i'm not saying it's ok, i'm just saying that it isn't a "OMG my engine is going to blow up and kill me and destroy the world" type of situation. hell, a large amount of pinging goes undetected as it isn't audible inside the cabin. and anyone with a stock ecu (or a nistune) shouldn't be overly concerned as the factory ecu will back off the timing if it hears it, providing the knock sensors are working properly.
  • 1 month later...
Just look on ebay or wherever, it's pretty easy to find splitfire or yellow jacket coil packs to replace your *insert car model here*
Edited by mosquitocoils
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
