Hey guys
someone managed to pull the plugs of the end of my defi sensors. the ones that go into the control unit
i have the plugs but just need to know which wire goes into which pin of the plug for the exhaust temp,oil pressure and fuel pressure
any help would be greatly appreciated, as defi dont even have a contact number or email:(
thankyou
Edited by johnnyt
https://www.sau.com.au/forums/topic/298311-defi-plugs/
Logically, red would be power, black be ground, and gray is signal. Use a multimeter on the control unit to probe out the power (most likely 5v or 12v) and the ground, and the one left over will be the signal wire
https://www.sau.com.au/forums/topic/298311-defi-plugs/#findComment-4963018
Hey guys
thankyou
Hey buddy,
I got all excited when I read this topic as I have a set of defi gauges sitting in the wardrobe waiting to go on.. But I only have boost/water temp :)
Water temp is a two pin plug, Blue with two black wires (Helpfull)
Boost is a white 3 pin plug, Red White then black is the order this goes in.
This is kind of in line with your picture, I hope this help..
I've always worked on trial and error...
https://www.sau.com.au/forums/topic/298311-defi-plugs/#findComment-4963579
ok guys.. thanks for the help with the wires!!
now if anyone ever needs replacement defi plugs. you can get them from RS components.
part numbers
3 pin- 476-6776
2 pin- 476-6760
i have looked everywhere for these things.. jaycar,dicksmith,altronics.. you name it, then i stumbled across RS and wallaaaa
thanks
https://www.sau.com.au/forums/topic/298311-defi-plugs/#findComment-4965536
