i wona put a little thread togeather with all the fuel ecconomy solutions you guys have,,
so far ive gota
safc, safc2 or better again safc neo
sitc to some degree
coilpacks
opening up the exhaust.. preferably 3' cat also so it doesnt bottle neck.
what eles have we found that will improve?
obviously regular servicing, good fuel etc are all factors aswell.
https://www.sau.com.au/forums/topic/298322-the-fuel-ecconomy-thread/
With factory ECUs (Un-touched Nissan engineering).
-Boost levels no higher then 7pound
-Retain Carbon/Emission Canister
-Good Heat Shield / CAI (heat soak = no power = lead foot to get her moving)
-Clean Air Flow Meter / Filter
-A Fully Operational 02 Sensor
-Drop all unnecessary weight (useless cargo)
-Lay off the throttle.
My two cents :nyaanyaa:
Tune and o2 sensor
I went from round ~350km per tank with bolt on mods and 10psi and no tune,
to ~650km per tank after nistune chip and tune and new o2 sensor!!
Obviously if I stomp on it round town I get less, but it did Melbourne to Albury on just under half a tank, including driving out of inner city Melbourne. That's over 300km!
I couldn't believe the difference.
Do a search you lazy flamin mongrel, its been covered so many times!
sitc to some degree
coilpacks
SITC to some degree? I disagree. To get the most out of your SAFC you need an SITC to add in or pull out timing as when you bend the fuel curve it also has a affect on the timing. Eg. Leaning of the air flow with advance timing (negative relation ship between the two)
Also coil packs are only going to affect it if the oem nissan ones are shagged.
Basically you want:
Easily breathing car (intake and zhorst)
Good spark (plugs and working coils)
Functioning O2 sensor
Clean fuel filter
some way to tune it all (sitc safc nisstune ect)
I think I'm needing to buy shares in BP.
RB26 is near impossible not to fang around in, so I pay dearly for the privilege.
Not complaining but its always the impossible. I want the maximum amount of power, for the least amount of fuel consumption LOL.
I hear quad rotary engines are offering that, before there even modded haha.
I'm currently running a completely stock series 2 and getting just under 530-580km around town with some spirited driving. Have a nistune to install, turbo back exhuast at the same time, and might put on a pod filter too. Will see how it goes after all that and most likly revive this thread haha. There will be a 100 000km service before then aswell... soo all fluids, spark plugs timing belt etc.
Edited by stagman
I am putting our fairly stock stag on the Dyno and I will come back and report the findings.
I bet its going to be rich as hell , and I have been harrassing the woman to get a nistune but as someone rightly noted a front mount is probably a better starting point before we go the Nistune.
On the front mount note, as is the case with the Rich, easily reached "R & R" late series 1 ECUs, fuel economy gets deadly once you install one with no engine management. I put my front mount in first as a preparation mod... in preparation for later mods. If I had my time again, I would go engine management first, but my emanage ultimate is in the post, and I have only been able to drive my car around for a collective 3 weeks since I installed the intercooler, so it's much of a muchness. Engine management before notable airflow increasing modifications FTW (If you are looking for economy).
I'll update fuel economy on the rig as soon as the emanage is installed, at the moment it is so bad that I can basically see the needle drop everytime the throttle is opened up :)
harts.
just needa learn to control your right foot, adam!
i do but it ALLWAYS seems to come on to some for off boost when i take off like 1 or 2 psi... chris can take off with like -1 or 2 lol...:)
wats the go with catalytic converters... is the stock one better than bashing it out?? ive got mixed thaughts... with the gridding in there it will direct flow well.. but slow it down aswell i think :S gutted cat or leave it?
alright,well that cat didnt fit.flanges on the wrong angle and an inch too short.
lucky the stags booked in in the morning for some exhaust work
You should have went all macgyver on it... it would have fit eventually...
After I got my boost controller and highflowed turbo etc I was getting around 15 to 20 L per 100km. When I got the 550 injectors and another tune it was pretty much 20L per 100km. Most of my trips are short and I like to boot it as soon as it has warmed up so I was filling up at around 300km!
The best economy device (and it was not intended that way) has turned out to be my new GTR 5 speed manual box. I went away for the weekend - I drive at 110km (the most you can do without getting pinged as i am a driver by trade and can't afford to lose my licence) with probably a dozen bursts up to 140 or 150 to get past traffic and a twenty minute full boost climb up a range of hills (each way) and managed 12L per 100km. I know this was on a trip but I used to get worse than 15L/100km before.
So that confirms what a lot of people think - the auto sucks gas. I find that I can drive around town mostly in 4th and 5th as it will pull steadily from 1500rev/min and goes well from 2000 rev/min even though serious power comes between 4000 and 7000 rev/min. Previously at those speeds the auto would be kicking down all the time.
On the other hand if you are not planning on lots more power the auto is great for city driving and if it is regularly serviced and not abused will (some people's bad luck not withstanding) perform well for years.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
