Ok its been sitting around awhile so its time to sell it :nyaanyaa:
This is my old PC, atm has no operating system on it and the hard drive is blank (bought it last month to get it running so its brand new)
Specs:
Case: Cooler Master Ammo 533 - http://www.coolermaster.com/product.php?product_id=5
Motherboard: ABIT Nf8
Graphics Card: Palit Nvidia GeForce 7600GS 256MB DDR3
Ram: 1GB Kingston and 512MB of Twinmos
Harddrive: Seagate ST3320613AS Barracuda 7200.11 320GB 7200rpm SATAII/300 16mb Cache
CPU: Err some AMD anthon (can try find out if you really want)
Looking at around $150 for it, that's the tower and everything in it, will give you power cords if you need - Dont really want to mail it, come round and get it :P
Cool wall doesn't come with the pc btw... unless you wana pay $20 for it :)
Next thing - M2R Helmet, got this awhile ago only used it twice, never in a crash
Umm not really sure on any specs or what i bought it for, so $120?
https://www.sau.com.au/forums/topic/298324-decent-pc-and-m2r-helmet/
  • 1 month later...
  • 3 weeks later...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
