I'm interested in the G/box and how do u know that they have only done 70k?
And would u take $1100?
i got the gearboxes out off two half cuts my mate bought and the reading where off the dash, one done 72000 and the other 78000. PM me if you want to talk about the price.
$700 for the two and the has have been anodized in purple.
Do you mean the alloy hat that sits over the hub has been anodized in purple?
Also are these just the 2 piece disk rotor set or are they actually a two piece "floating" rotor?
Finally, do you know if the rotors are the DBA 5000 series?
Sorry for the 40 questions...
Cheers Cam :D
Cheers Cam :D
i think they are the 5000 seires cause dba only make two diffrent types for that car the normal ones and the floating ones. yes the hats are anodized.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
