Item Summary: R32 GTR 570hp at all 4s or 430kw
Condition: Used
Reason for Selling: down grading
Asking Price: 45000
Delivery Methods: PickUp
Contact Info: 0412299653
Extra Information:
10 sec street machine
570hp at all 4s or 430kw its a crazy car hits hard and just insane power for a street car
only done about 4500ks on new engine coast $30k alone just for engine have recipts for $80,000
full race os giken box race fuel system the works serious car please no time wasters PLEASE
prob so so much more but if you want more info just ring or pm me any questions
will trade for a nice luxury car
quick vid on the build
CP PISTONS AND RINGS 86.5MM
EAGLE RODS
TOMIE FULL METAL GASGET SET
TOMIE OIL PUMP
ATI BALANCER
ACL RACE SERIES MAIN AND BIG END BEARINGS
HKS VALVE SPRINGS
ARP HEAD STUD KIT
ARP MAIN STUD KIT
NISSAN GASGET SET
JUN CRANK COLLAR
TRUST SUMP EXTENSION
HKS FUEL RAIL
SARD FUEL REG
HKS 115MM THINK INTERCOOLER
HKS CAM GEARS
POWER FC ECU
GARRET GT35R TURBO
TOMEI PONS CAMS \
TWIN PLATE 800HP CLUTCH
Edited by bigme
https://www.sau.com.au/forums/topic/298353-r32-gtr/
  • 3 weeks later...
please no more low ballers been getting offerd 35k no i will not take that i rather hang on to it than let it go at that price
i have spent way way to much time money over $80k on this thing its a full 10s street GTR very hard to find in great condition and this reliable never misses a beat
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5033563
$45k? That's R34++ territory.
Awesome work though, I would keep it if I put that much work into my car!
Find me a 34 GTR with this sort of work done for anywhere near that money and I will grab it!
Pretty unfair sort of comment mate, and probably not very constructive to the sale!
this car is great value...
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5037677
just so people know
$3500 worth of goodies under car put on 3 weeks ago sway bars front and rear udjustable camber arms lower and uper controll arms every bush replaced and more
also new brembos all round with bigger 33GTR MASTER cyinder pulls your face of how fast thing pulls up :)
also everything just got mod plated single turbo fuel system batt in boot and all the brakes so 100% leagel very hard to do
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5051384
I don't think I wrote anything negatively about the sale, only that the car must have had a lot of money spent on it. I remember Leewah's car, there will be buyers for this sort of thing!
What year is it?
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5055650
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
