Item Summary: R32 GTR 570hp at all 4s or 430kw
Condition: Used
Reason for Selling: down grading
Asking Price: 45000
Delivery Methods: PickUp
Contact Info: 0412299653
Extra Information:
10 sec street machine
570hp at all 4s or 430kw its a crazy car hits hard and just insane power for a street car
only done about 4500ks on new engine coast $30k alone just for engine have recipts for $80,000
full race os giken box race fuel system the works serious car please no time wasters PLEASE
prob so so much more but if you want more info just ring or pm me any questions
will trade for a nice luxury car
quick vid on the build
CP PISTONS AND RINGS 86.5MM
EAGLE RODS
TOMIE FULL METAL GASGET SET
TOMIE OIL PUMP
ATI BALANCER
ACL RACE SERIES MAIN AND BIG END BEARINGS
HKS VALVE SPRINGS
ARP HEAD STUD KIT
ARP MAIN STUD KIT
NISSAN GASGET SET
JUN CRANK COLLAR
TRUST SUMP EXTENSION
HKS FUEL RAIL
SARD FUEL REG
HKS 115MM THINK INTERCOOLER
HKS CAM GEARS
POWER FC ECU
GARRET GT35R TURBO
TOMEI PONS CAMS \
TWIN PLATE 800HP CLUTCH
Edited by bigme
https://www.sau.com.au/forums/topic/298353-r32-gtr/
  • 3 weeks later...
please no more low ballers been getting offerd 35k no i will not take that i rather hang on to it than let it go at that price
i have spent way way to much time money over $80k on this thing its a full 10s street GTR very hard to find in great condition and this reliable never misses a beat
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5033563
$45k? That's R34++ territory.
Awesome work though, I would keep it if I put that much work into my car!
Find me a 34 GTR with this sort of work done for anywhere near that money and I will grab it!
Pretty unfair sort of comment mate, and probably not very constructive to the sale!
this car is great value...
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5037677
just so people know
$3500 worth of goodies under car put on 3 weeks ago sway bars front and rear udjustable camber arms lower and uper controll arms every bush replaced and more
also new brembos all round with bigger 33GTR MASTER cyinder pulls your face of how fast thing pulls up :)
also everything just got mod plated single turbo fuel system batt in boot and all the brakes so 100% leagel very hard to do
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5051384
I don't think I wrote anything negatively about the sale, only that the car must have had a lot of money spent on it. I remember Leewah's car, there will be buyers for this sort of thing!
What year is it?
https://www.sau.com.au/forums/topic/298353-r32-gtr/#findComment-5055650
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
