as above. I'm trialing a few of these BEFORE I bring a bunch of them in to sell.
I need a OEM radio equipped car (bose or non bose - don't care..) to put this into for a month or so. it's no cost to you and you need to have an iphone preferably.
the aim is to provide an iphone solution for these cars with direct control off the radio/ SWC for the unit.
car needs to be in brissy and the install will be done here.
takers?
https://www.sau.com.au/forums/topic/298372-need-a-mule-brisbane-based/
I'm confused, havent you done the iPhone connectivity with HU or SWC already Chris? The only missing link being BT I guess.
I control mine via HU, SWC or phone itself. Dock puts it in a good spot for usage and speakerphone calls, and charges, works a charm. I was originally investigating a BT solution but music mutes when i get/make a call and speakerphone works so well it hasnt been necessary.
and the coolest thing... when you dock, it will automatically start playing wherever it paused when you pulled it out last. No need to go into the ipod part and press play or anything, it just starts.
no I've done a ipod solution into one. ths one is done via the radio and OEM SWC controls.
I have a mule for it now and you probably wont hear anything for 6-8 weeks whilst this piece is on trial.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
