Caltex Vortex 98. But any 98 RON fuel is going to be better for your engine than 95 RON premium or normal unleaded. Increased power and or better economy (depending how you drive it) and perhaps even more importantly less sh#tty deposits on your injectors inlet manifold/ head ports and plugs.
Not sure a higher RON value is going to make for a better or cleaner fuel. You can take a shit fuel and add octane booster and it still will be a shit fuel. I used Vortex for a while because it was close and easy but t.b.h. it's not that great. I've had better economy and much better performance from BP Ultimate. If I use anything else after ½ tank the difference becomes noticable.
Yes I agree, I'm using Caltex 98 recently because of the Safeway promotion and only get 150km around the half-tank mark! Used to use Mobil 98 which brought me at least 200+ km.
I've tried Shell and BP - they are both alright, but Mobil seems the most consistent with my V35.
BP 98+ or Mobile 8000 when I'm going for a decent drive or to the track, V-Power for the rest of the time.
Just bugs me that around my area BP 98+ is usually about 15c a litre more than V-Power (plus another 4c if I have a fuel discount coupons from Coles/Shell) and no Mobil stations with 8000 (98RON). Because the V35 definitely 'feels better' using BP/Mobil and gave about 1.1 - 1.2km/l better fuel economy on my Syd to Melb trips according to the 'green leaf-o-meter'... though I probably not advise you take those results as science!
which fuel do you use to fill up ?
BP Ultimate :rofl: ....reason being is that its a cleaner fuel then the rest of them and the only fuel that has a green house tick on this fuel. correct me if iam wrong. it depands on the individual car and their set up.
BP98, Mobile 8000 and Vortex 98 - went to 2 BP stations and both BP 98 were out of order - bone dry i guess so i went to caltex for vortex 98 took 10 mins to reach the pump some people are just stupid these days they look and stare at the pump and fuel type like if they dont know what the hell fuel there getting or its there bloody first time putting petrol into a car...this is while nozzle is in....boils my blood i tells ya!
  • 1 month later...
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
