hey guys, they day has come to replace my stock turbo and i have no experience in this field so some help and answered questions would be great.
1. my friend has a 2nd hand t3 turbo, is it bolt on..and what would be a suitable price to offer him
2. where would i go to get it compression tested...and if the t3 turbo isnt bolt on where can i go to get it high flowed.
3. which of the 2 is the better option. thankyou.
https://www.sau.com.au/forums/topic/298388-need-a-new-turbo/
how much do you want to spend and how much power do you want to make
a "t3 turbo" is like saying you have a "computer" for sale
there are million different pc manufacturers, combinations, models, variants, specs, speeds, etc, its impossible to clasify it as a "computer" much like a turbo as a "t3"
typically "t3" spec turbochargers are cheap ass-spec units either sold on ebay or from dinosaur spec cars like vl turbo's etc - probably the standard one is better and easier to fit
a no-spec'd t3 is worth no more than $300 ? it could be complete junk on your skyline?
a brand new ball bearing garrett spec is typically $2000, so a sub $300 is going to be shithouse
a 2nd hand R33 turbo is worth $200-$300 in comparison
get the turbocharger compression tested or your engine? you can't compression test a turbo, but you can get it inspected, checked and verify of specs and/or model etc
ATP in melbourne can do it for also some well known workshops can inspect them for you and do basics checks, but for true check i would check with ATP
ATP is the only place i know of, there would be heaps more in vic, some other guys will post up some places
if the turbo isn't bolt on, it isn't bolt on, period. highflowing it doesn't make it magically bolt on.
if the t3 turbo you still want, doesnt fit, then youll have to change stuff to make it fit. probably flanges, bolt patterns, spacers, rotate the housings etc to make it fit
highflowing the turbocharger involves a replacment of all items that are perishable (compressor wheel, exhaust wheel, bearings, seals) and the only things that remain original are the cast iron housings. the replacement items are higher flowing spec (thus the term highflow) so it makes more power for the same sized unit.
way i made it easy for me.... what HP do you want ? get that, then it nail's down the snail's and you dont have a few hundred to go through, just a couple.
easiest way i did it was horsepowerinabox.com they have turbo's and HP rating, Flange spec, then i went off onto google and forum and read up on applications, and what else is needed to run the turbo.
but yeah once you work out your HP you want, its much more simple
to be honest im not after huge numbers, even just the same power i got out of the stock turbo..maybe a little extra.. i dont want to spend major bux...do you have the number of this ATP place if you do please pm me it thanks.
p.s i didnt realise there are different types of t3 o.O thought it was just one brand, goes to show what i know.
and what i ment was, can i just high flow the stock turbo i have? would it be cheaper
well wen i read your other thread, u said u had a problem with the turbo's wheel. i thought high flowing would fix that..someone plz correct me if i'm wrong.. but yeh, price? you're looking at about 800 to 1500 bucks for a hi flow job..
wow...i thought if u keep the stock n high flowing it, it would be cheaper then buying a new turbo?
It is cheaper than buying a brand new turbo,,thats if u want something good for your car..high flowing will just replace the interiors of your turbo with stronger parts and makes the housing bigger. u can look them up, im sure theres a thread somewhere here about it,if not, google
but if all you're looking for is around 200kw, better off just buying a second hand r33 one
never heard of a "t3" turbo myself.... many turbo's have a t3 type flange :D
i'd say if you're not fussed about big power, want to maintain stock low mount position (bolt on), re-use your oil/water lines (although i'd suggest replacing them anyway), and have the same level of punchy response with a quick spool.. then a high flow GCG turbo should suit your needs.
+1 for going to hypergear to hiflow your turbo he does great work and for the money youll pay you could see 250kw with supporting mods with the standard r33 turbo housing. From what I have seen the only really compelte bolt on kits are the hks ones but they dont come cheap I highly reccomend for you purpose a hi flow since its really a direct bolt on
never heard of a "t3" turbo myself.... many turbo's have a t3 type flange :rofl:
all vl drivers seem to classify there turbos in terms of t3, t4 etc
Mmmmmm flange.
yerh i called him up and got a price, it probably seems like the cheapest,best option to go for. what would be a safe psi setting to run on the high flowed turbo when i get it.?
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
