Hi People,
I have a fresh mystery at hand (without solving that other one about a disconnected hose in engine bay).
Yesterday when driving home, I noticed a squeaking noise (sort of like the springs of on old bed) coming from the rear left of the car every time I would turn. When walking away, I saw a dettached cable coming out from underneath the back of my car (R34 gtt). It seems to be a steel cable wrapped in what looks like a thermal/heat-proof material. The end seems to have some threading (suggesting that it may screw in somewhere, or something screws onto it). But I can't seem to see anything except a few holes in the underbody (nothing with threading) where it may attached to.
The first pic shows what it basically looks like. The second pic shows where it is attached (on the back left, inside the "support" for the rear bumper i guess). There isn't one on the other side (the place where it would go is plugged by a piece of rubber).
It's on the side of the exhaust...So I'm thining it might be a cable to support the exhaust? But I've never seen a exhaust supported by a cable.
-Is it possible the exhaust was making the squeaking noise when the car was turning?
-Is this cable to support something to do with the suspension etc? if so, why would it be attached to the the inside of the bumper support?
-Is it some sort of grounding wire?
http://i962.photobucket.com/albums/ae103/v.../IMAG0130-1.jpg
http://i962.photobucket.com/albums/ae103/v...23/IMAG0131.jpg
The next time someone looks under their R34, please let me know what this is and what it connects to? Or if you want to be an absolute legend, take a pic on your phone :)
Edited by DriftinThruLife
Its for the genuine exhaust. Low throttle one of the exhausts close/restrict, but once you start getting the revs up it opens up. It mentions it on the R33 factory manual - the r34 factory manual does not mention it..... *someone please correct me if I'm wrong.*
hi, yep i thought that too when i looked at it. although on the 33 its closer to the front of the car, but I do think that imho that is what it is. obviously the exhaust is not stock. and they didnt incorporate this.
My GTT has a big stainless steel bracket for the aftermarket muffler in the same spot. nothing else
it wouldnt be a handbrake thats not even close to it.
to test , with cool tailpipe, lay on the ground and wiggle the muffler, 90% sure its a broken off bracket on it. and it would squeak like a old truck on corners/take off. bumps etc.
unless its something added by the aliens ????
Hey all, thank you sooo much for your replies. This morning I was like "damn zero replies"...and now it's like "ch-ching! jackpot".
The fact that a few of you don't have it, puts my mind at ease...since it's not an absolutely necessary thing. Just out of curiosity..those of you who don't have it...do you have stock or aftermarket exhausts?
Since iseekool mentioned it's for the geuine/stock exhausts...mine's aftermarket, yet the cable is there. But I'm guessing it WAS getting used, since the dettached cable and squeaking happened at the same time. unless it's a coincidence?
I'll start looking more closely around the exhaust area, and see if I have any luck. If I can't attach it normally, I guess I could make some sort of metal harness for the exhaust to sit in (as long as that squeaking stops).
PS: i seekool...is that anything to do with the SPORT/SILENT exhaust switch? Whenever i press it, I can hear something moving...but don't notice anything sound-wise...I guess coz it was meant for the standard exhaust.
Once again, Thank you all veryy veryy veryy much :(
Once again, Thank you all veryy veryy veryy much :P
I just recently changed my exhaust and there was no such contraption on the stocker.
Once again, Thank you all veryy veryy veryy much :down:
Kaching! Lol!
My bet would be that if you looked under the car at that thing while a mate pressed the exhaust switch it might move :blink:
It kinda looks similar to an actuator of sorts. And if it was for the factory muffler then it would open/close something inside.
Hi People,
The next time someone looks under their R34, please let me know what this is and what it connects to? Or if you want to be an absolute legend, take a pic on your phone :blink:
My guess is, it is your Exhaust Temperature Sensor.
If you had a look, there should be a EXH Temp Warning embroidered on your sun visor on the driver side, in Japanese (That's probably why you didn't read it LOL!)
Again that's for the R32, on the R34 maybe different...
I know R32's had them and mine has been cut off, just a cable hanging cuz of my aftermarket exhaust when it came with the car.
But R32's had it near the Cat converter... That's why I can only guess for the R34.
Exhaust Temp Sensor is there to warn you, when the exhaust gets really hot, the temp light will come on.
How does an exhaust get hot? When the engine is running, giving it a good spirited run down the track, but were talking excessively high temps.
That's my guess.
That's my guess.
I actually think your referring to a cat temp sensor, rather than an "exhaust temp" sensor.
Every car i have had has it, and its actually there more to tell you that your cat is f**ked/blocked.
Because the cat catches all the nasties, over time it clogs up and causes restrictions. And the restriction will obviously create alot more heat than normal because your forcing the same amount of exhaust through a more restricted area.
If the cat is in good working order, or not there at all (decat), you shouldnt ever see the temp light on the dash come on at all, even on the track.
Oh i see. Thanks guys. Eiher way...whether it's some sort of cable for pulling (silent/sports mode) for the standard exhaust....or a cat temp sensor as you have mentioned....I guess I should leave it on (as opposed to cutting it off) just incase I ever have to put the standard exhaust back on. But yeh, for now I've just just used a cable tie to hold it up and away from the road. Still don't kow what that squeaking is. maybe something wrong with the suspension. I don't know. Oh well. But I guess the cable mystery is over.... Now i'll have to try and solve that other thread I have....about the mysterious unconnected hose in the engine bay. Thanks for everything people. Very very appreciated =)
I see,
That makes sense, thanks for clearing that up :)
What I said in my post is what I was told, but your answer makes more sense.
Cool!
:laugh:
    • If you ask just me you'll get 3 different answers.
    • Do not ever trust ChatGPT with anything math related. They can't do math. They have no idea what it is. With enough data we can fit a decent equation in Excel, or if the available fits in Excel aren't good enough, a Matlab clone.
    • You could check/calibrate that with a thermometer, we have long glass thermometers at work which go from -10 to +150°c, they are pretty cheap too I believe,  as monkey fisted soldiers tend to break them, and getting new ones don't seem to send red flags to the people that hold the purse strings Edit: after a google they apparently cost about $80, but, digital ones seem to be much cheaper at around $40
    • I should have prefaced all of this with "I'd really like to not pull anything out of the car for this"
    • Me, I would happly spend some more coin on better tyres for my street car  Will they work, yes, of course, but why substitute some dry grip/braking distance, and wet weather grip/braking distance on what is really old tech to save some coin on your "precious" street car In the end it might not be you that farks up, it's the thousands of other idiots on the street that you need to worry about  For a street car that gets some "fun time", I have found that a quality tyre that can handle dry, wet, cold (Canberra gets pretty cold) and hot conditions, which may costs a little more, is great insurance  From my experience with them (driving around Goulburn in the winter) the RE003's are pretty poor in cold and/or wet conditions on the street If RS4's didn't hate gripping in the cold I would be running them always on the street,  great in the dry, OK in the wet, but, they do hate the cold, with a passion, I run PS5's year round now, basically, I've found the PS5 to be a great year round street tyre for all conditions, they last well, and are mid range pricing wise TL;DR. Tyre choice is probably like what brand and grade oil you should use, ask 10 people, and get 10 different answers... LOL
