Coilovers are in excellent working condition, I am selling as they are no longer needed.
Height and damper adjustable
Adjusting spanners and allen keys included.
Some info on the coilovers:
- All G4 Racing Shock Absorbers are seperate gas and oil (30% Nitrogen, 70% Oil) monotube design, which prevents oil leaking defects.
- The shock absorber also includes high-performance front pillow ball top mount on McPherson Strut type only.
- Shock absorbers are made by lightweight 6061 aluminum alloy and anodized to avoid color loss.
- Most models can be lowered to 110mm lower than the original height.
- Damper can be adjusted up to 36 ways.
- Teflon thread coated to prevent rust and corrosion.
- Fully Rebuildable in Australia
Asking for $550
PM me if interested
They can be picked up or posted at buyers expense postage should be about $40 dollars aus wide.
futher details 0408491953
hi,
where are you ?
what kinda application are these suited for ? street or track?
I'm in Newcastle, NSW, but I can post them anywhere if needed. I bought them for street use.
X 2 + How old/ how many K's, - raced ?
Basically new, were used for under 3000kms, only used for normal street driving.
Cheers :D
how come you are selling?
x 2 + what spec damper cartridge do these have, I'd buy them in a heartbeat but I'm concerned that they may be to harsh for street which is all my ride does-or will do as long as I have it.
:down:
Putting a new setup in the car with Koni yellow's and no longer need them, plus need cash for my new sway bars :D
:D
the factory supplyd spec damper, had these at basically factory height and on the softer setting wasnt harsh at all quite streetable :)
