Coilovers are in excellent working condition, I am selling as they are no longer needed.
Height and damper adjustable
Adjusting spanners and allen keys included.
Some info on the coilovers:
- All G4 Racing Shock Absorbers are seperate gas and oil (30% Nitrogen, 70% Oil) monotube design, which prevents oil leaking defects.
- The shock absorber also includes high-performance front pillow ball top mount on McPherson Strut type only.
- Shock absorbers are made by lightweight 6061 aluminum alloy and anodized to avoid color loss.
- Most models can be lowered to 110mm lower than the original height.
- Damper can be adjusted up to 36 ways.
- Teflon thread coated to prevent rust and corrosion.
- Fully Rebuildable in Australia
Asking for $550
PM me if interested
They can be picked up or posted at buyers expense postage should be about $40 dollars aus wide.
futher details 0408491953
hi,
where are you ?
what kinda application are these suited for ? street or track?
I'm in Newcastle, NSW, but I can post them anywhere if needed. I bought them for street use.
X 2 + How old/ how many K's, - raced ?
Basically new, were used for under 3000kms, only used for normal street driving.
Cheers :D
how come you are selling?
x 2 + what spec damper cartridge do these have, I'd buy them in a heartbeat but I'm concerned that they may be to harsh for street which is all my ride does-or will do as long as I have it.
:down:
Putting a new setup in the car with Koni yellow's and no longer need them, plus need cash for my new sway bars :D
:D
the factory supplyd spec damper, had these at basically factory height and on the softer setting wasnt harsh at all quite streetable :)
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
