  • Replies 44
Don't mean to judge, but by the sound of you, I think you underestimate how much time/effort/money would go into a 320rwkw build...
at the VERY LEAST, your gonna need a 20psi + capable turbo to reach 320rwkw, plus i doubt stock internals are good for 320rwkw.
so youd need:
fuel pump
injectors
bigger turbo (GT35, TO4z/e)
pistons/rings
rods/bearings
head gasket
head studs
cams (not necessity but would make things easier)
aftermarket engine management
big exhaust
big breaks
then apart from that, for drifting youd need:
coilovers
separate rim/tyre combo
a good diff
oil cooler
clutch and/or flywheel
but yeh, you could go to town with an engine build.
all depends on your application...
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964212
I made 320rwkw in my r33 streeter using the following:
Built motor (rb26 crank and rods forged piston)
Garret GT3082r turbo on 6boost manifold with turbosmart gate
Hks step 1 cams
555cc injectors
blitz fmic
trust 3" exhaust
Hks ecu
If I were to build an engine from scratch for drifting I would aim for lower power and more response.
250rwkw with nice response is much more fun than 320kw with lag.
I'v seen plenty of rb25s make 300kw on stock bottom ends so if you weren't worried about long term reliability you could probably make 300kw with just basic bolt ons. maybe
gt35r turbo
700cc injectors
nistune
the usual intake and exhaust?
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964253
i would say my setup is ideal for what you are after:
i make 285rwkw on pulp and 320rwkw on e85,
so you can have good enough response for drift, and 320 when you want it for the strip....
motor is stock
hks 2835 pro s
nismo 555cc injectors
nismo fuel pump
hybrid gt FMIC
apexi power intake
steel induction pipe
cold air box with intake
z32 afm
apexi power fc
blitz dsbc spec s
fc datalogit box
3" turbo back zorst w decat
thats $10,000 in parts right there...
and then there's installing the shit.... you can do that yourself, or pay.
and then there's tuning...
you'd probably get away with around 2k for both...
in my opinion you also need the following to make it worth the effort:
button clutch $1.5k+
mech diff $2k
suspension mods $4k+
good rubber $1.5k+
so realisticly that's a $20,000 power level when its all said and done... however it can be done cheaper... but not heaps...
you could also use a 2nd hand highflow, stock injectors, stock afm, stock clutch, stock suspension, shit rubber, no name fmic, no name zorst, manual boost cont, greddy emanage, welded diff and be happy with a responsive 230rwkw for around say 3-4k....
you really have to ask yourself which direction do you want to go?
personally after its all said and done, i'm very happy with my car how it is, but would i do it that way again? probably... but i'd try not to.... :D
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964314
Personally for that power level and stock engine i would be running E85 and the following mods.
3037 on standard exhaust manifold with 18psi can
Power FC or Vipec (alot of users rave about the vipec)
Sard 850 injectors
Bosch 044 internal pump
Standard inlet Manifold
Decent Boost controller
Blitz LM cooler (retains stock inlet piping)
Z32 AFM
Real good exhaust 3.5inch
On 20 ish psi you should see upward of 320rwkw with a good tuner.
Heres a dyno graph of my mates R33 and mine, his in Red and 3582 turbo... my car in blue running HKS3037.
Oh and a pic of my engine bay to show how stealth you can have it all looking.
Edited by RB25DETS2
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964392
And then... when you bust a motor, which is certainly on the cards @ 300-320rwkw...
Add another 5-10k on top of the 20k.
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964432
Personally i wouldnt push my RB25 past 280rwkw on pump fuel. My XR6T is happy as a p*g on 16psi and 327rwkw pump fuel (something to be said for cubic inches i guess).
Edited by RB25DETS2
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964489
As said above there are a number of ways to get to your goal but dont look to spend less then 10000 and then you got the question of the path you follow you can go the cheapest path which using cheap parts and pumping as much as you can into your stock motor and get the power but not being safe for your engine or you get the quality bolt on parts you and build it up to that power level slowly and also making a decision along the line once you pass 280kw to keep going since your putting the stock engine at risk or you can just go all out and get the motor built to take the power and get all the supporting mods done properly, in my opinion as this is what I did save up for all the bolt on and supporting mods you need do them first then get your car at a power like 280kw where is still somewat reliable on stock engine and when you feel you can afford to fork out for a new engine push the engine so even if it does give out youre atleast prepared for a rebuld
https://www.sau.com.au/forums/topic/298416-320kw-stock-33/#findComment-4964907
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
