  • Replies 44
you "BOUGHT" a stock R33.
BOUGHT = purchased
BROUGHT = to bring it somewhere with you.
Hope this helps.
You have no idea how much this sh!ts me. Its one of my pet peevs. How can soo many people get that wrong. It basic English FFS!!!
/end rant
Sell your car for $10k, buy a $18k built R33 with 320rwkw.
Cost $8k
Or do it yourself and spend upwards of $20k on top of your purchase price lol, oh not to mention the 2 years it will probably take to get all the parts, put it together and make it work.
Cost $8k
buy my r33 its up for sale in SA 330+rwkw on a forged engine, has all the parts and brakes, plus its a SLEEPER
Personally for that power level and stock engine i would be running E85 and the following mods.
3037 on standard exhaust manifold with 18psi can
Power FC or Vipec (alot of users rave about the vipec)
Sard 850 injectors
Bosch 044 internal pump
Standard inlet Manifold
Decent Boost controller
Blitz LM cooler (retains stock inlet piping)
Z32 AFM
Real good exhaust 3.5inch
On 20 ish psi you should see upward of 320rwkw with a good tuner.
Heres a dyno graph of my mates R33 and mine, his in Red and 3582 turbo... my car in blue running HKS3037.
Oh and a pic of my engine bay to show how stealth you can have it all looking.
Stealth is the way to go. Especially since your new car is cop bait, the last thing you want after spending all your money modding, is to have that nice yellow sticker on your windscreen. I've gone the "stealth way" and I'd be more than happy to let a copper inspect under my bonnet... hmmm, that doesn't sound right...........
exactly... got pulled over the other day... only got defected for pod as they could not see my low mount 3071R :)
gotta do something about that pod tho... $84 everytime i get pulled over...
PS buy my 260rwkw Skyline... much cheaper than building one yourself OP :D
Hahahaha.
Havn't seen you around in a while man :blink:
yeah.. work started making me work for my money.
and I got rid of the skyline so I kinda spend my time elsewhere..
but you know..
occasionally come back to see what's crack-a-lackin and that..
watsupwitchoo?
Brought anything for your car lately?
Cheapest 320kw i can think of:
Take your 25 apart. Get a $400 rb30. Keep the short motor. Clean up the surfaces on the head and the block. Get that head welded up. While the head is off take to it with a drill and tap in a little fitting to drain your oil back into the sump. Just T it into your turbo drain if you want. And bolt the rb25 head back on. Should be about $200 in labour for the tidying of the head. Use your standard manifolds and all that. Chuck on an XR6T turbo. Grab some 550 nismo injectors as they will just plug into your stock wiring loom. and put in an 040 fuel pump. Oh and grab yourself an ebay cooler and an rb20 ecu. :) Use a std nissan head gasket
That is keeping things as cheap as I can think of.
Edited by Lukas 33
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
