  • 2 months later...
  Gdekwant said:
id assume more. call some workshops if your truly interested.
if nobody knows i will have to yes, thanks for your "assumption" lol.
Why answer a question if you dont know the answer?
If anyone does please let me know, if not make out i never asked
Its one of those conversion's where you can never give an accurate estimate as so many little things would need to be done.
Most workshops would probably give you and over inflated price to cover any unforseens to which you will most probably baulk at, then tackle it your self and then see why the large figure.
Factor in the motor, gbox, wiring, fuel sytem, fabrication of engine mounts, gearbox mounts, tailshaft, engine bay or trans tunnel mods, cooling sytem mods, exhaust etc etc and then there is all the fidly little bits (that VERY quickly add up), plus the killer of labour.
Go the RB25.
id suggest PMing bezerkR32. Stu is a great bloke and recently converted his r32 to ls1. He should be able to give you some good info.
Hope this helps,
-Sean
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
