hey guys and gurls
jst recently put a gfb bov on the r33 but didnt like it to much so took it off
but noticed that my stock boost guage was at -7 at idle now i put my stock bov on
and it sits a bit before-7 :s
cars still runing fine jst like it was before
turbo still excatly the same
could of it thrown out the boost gauge some how?
cheers guys
It'll be fine, just remember that you altered a part of the system that's supposed to stay pressurised.
The stock blow off valve is designed to leak a little bit when at idle, so I would suggest that changing from the GFB one (which wouldn't leak at idle) to the stock one would change your reading.
Cheers guys I was worried at first but the car is still
mechanicly sound , cheers guys I'll check the vac line tomorrow if I was to change my bov
would I need to get a tune or somthing coz I was looking to buy the greddy type s
Dont bother getting a tune if your only changing a BOV. If it is Recirculating back into the intake then nothing changes. If it is atmospheric then a tune wont really help unless you find an alternative to the factory Air Sensor (And even then you would only have to worry about the possible stalling issues caused by Atmo BOV's as covered in many, many a post before this)
Save the tune for big mods like injectors, turbos etc.
Luke
ahhh ok. im sure nissan would have designed a vacuum leak into the intake system to aid smooth idle lol.
Even if the BOV is designed to leak, it's a NOT going to affect idle as the "leak" is not escaping outside of the air measured by the AFM.
I don't see, how at idle, the stock BOV is going to be "leaking".
Air flows from point of highest pressure to lowest. When idling, the WHOLE intake up until the throttle body is at the same pressure...
The vacuum point is from the throttle body to motor side... Nothing to do with before it...
Maybe it leaks backwards :blink:
Except for the fact there's a vacuum line (from after the throttles) to the top of the bov which would suck it open unless the spring held it shut. the factory spring tension is soft enough to allow a small leak at idle.
Even if the bov were fully opened, pressure on the air filter side, and the IC pipe side is EQUAL, so there is no "leak".
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
