I got an S-AFC soon after getting my mildly modded car (T04 turbo, exhaust, boost controller, small FMIC) and it gave me a uniform extra 15rwkw across the board.
Then after a few more mods, which were a bigger FMIC, new front facing plenum, bigger fuel pump, upgraded wastegate actuator to handle more boost, and running higher boost, the car got 2 massive dips in the powerband even after re-tuning the S-AFC. I had more power up top, but it felt very flat after 5000rpm or so.
At this stage I upgraded to a PowerFC and it's fixed it. And I haven't even tuned it yet. I don't think it was a case of the ECU and S-AFC not handling the power, I just think the airflow was so radically different from stock that caused it to have a bit of a sad. There are other guys running over 215rwkw with S-AFC and no problems. Part of it is luck.
I say you should get a second hand S-AFC, and when the car starts not coping, sell it and get a PowerFC.
I know PowerFC is defectable in SA but is the SAFC?
are you serious?
how can the defect u for a PFC
coppers rip off ur kick panel and go "show me ur ECU"?????
its gettin beyond a joke this defect bullsh*t
Oh another question, with cam gears do you need a aftermarket ecu to run after market cam gears?
You don't need an aftermarket ECU to run adjustable cam gears but it may help. I installed mine and I found that the best setting was on 0 degrees (ie same as factory). This may change after tuning though.
You can't easily tune them yourself at home, best to do on the dyno where you can monitor the air fuel ratio so you don't run it too lean. If you know how to use a dyno properly it should take around an hour, otherwise give it to the workshop and they'll charge you around $200-300 for the same thing.
2GU UP
I am dead serious, the cops don't pull off the kick panel.
But the Registration office that does the inspections for defects will pull your car apart looking for stuff like this.
I have even heard of inspectors undoing the casing to look at the circuitry on the ECU to check that it is standard. You would have to be desperately unlucky I would imagine.
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
