Hey all,
Looking for a bit of advise and experience..
I recently picked up a needle bearing to replace a worn bronze spigot bush. Looking at the needle bearing its great quaility etc but my only concern is the rollers becoming dry and failing.
Has anyone used the needle bearing before and how many kms has it been in the car for?
Cheers
Johno
An apprentice that used to work for a place that sold roller ones told me they'd had some of them fall apart....If it were me i'd use a bronze stocker.
Thats what im worried about!
Thanks for the feedback guys, I think I'll play it safe and just use the stocker..
Cheers,
Johno
I think the stock bush isn't bronze, but some sort of other alloy that is self lubricating (cant remember the name of it right now).
I'd use the stock bush, they're only a few dollars from Nissan :D
It's a porus bronze, you are supposed to force oil through it before installing. So you block one end off with your thumb, fill it up with oil then squeeze really hard with your other thumb on top. Keep squeezing until you see oil seep out of the bronze. This way it become impregnated with the oil and provides the lubrication.
From http://en.wikipedia.org/wiki/Sintering
"Sintered bronze in particular is frequently used as a material for bearings, since its porosity allows lubricants to flow through it or remain captured within it."
So yeah add lubricant. My first guess is a grease would be ideal, but i havent checked the workshop manual maybe it says oil.
Thanks for your help guys, I put the stock bush in ($8 from Kudos Motorsports) soaked it in oil for a few days too..
The old spigot was a pain to get out.. wouldnt budge with grease but the "soaking paper" method did the trick..
Cheers,
Johno
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
