hey guys long story short,
i bought a r32 gtst auto (moved up the ranks into the nissan world previously into the rolla's) and started doing a manual conversion, i was sold the wrong parts and now they dont fit ;)
i started this thread beacuse i sick of getting screwed around so i wanted to know all the interchangable parts for the r32 gtst for example the master cylinder is the 180sx interchangable or the manual pedal box what oter car besides the r32 does it also fit. As r32 manual stuff is so freakn hard to find these days.
but yea please dont flame me alive beacuse i tried searching the forums and found one useful link about auto to manual conversion started by "gaffa".
any help woild be apreciated
thanks
https://www.sau.com.au/forums/topic/298452-r32-manual-conversion/
im doing the conversion atm, ive researched and been told i need>
Manual gear box
manual tail shaft, (their diff size apparently lol)
clutch pedal
manual brake pedal, or just shop the old 1, they too long sideways lol
clutch master cylinder with that metal hose and the push thingy on the gear box
clutch
flywheel
thats about it, from what i no
  • 4 weeks later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
