34's are considered the pic of the stock dumps
thought the were stainless so rust is weird?
found alot of stuff on my R32 has like one stud one bolt etc.
sometimes when you go to bolt it up it makes sence sometimes less so
If the flange faces are square/flat checked with a steel rule etc.
and thats all ya got go with em I reckon
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4964833
not sure if you plan to use o2 sensors if you do check my post here
http://www.skylinesaustralia.com/forums/O2...rs-t298491.html
reckon you will run into the same or similar problem as R34 o2 sensors are a larger thread and I suspect longer reach than R32
Flanges can be machined just extra cash involved if ya cant do it yaself or at least at mates rates
dont reckon it would be to pricey anyway
Edited by noone
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965222
If there are O2 sensors in there now then I plan to run them in the new dumps. I would not get mates rates and I'm sure as hewll not doing it myself. It's now a question of how much and more importantly who will do it correctly so the R32 sensors fit the thread and the depth.........Knew this would be a pain...
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965281
You're not talking about the old ones that may come in the dumps are you? o2s are a maintenance item, every 40,000ks or so.
Just take the dumps and the sensor to an exhaust shop. I had xforce dumps and they come with a hopeless adapter that if used wouldnt have put the sensor in the exhaust flow at all. Castle hill exhaust cut off the 33/34 mount and welded in the adapter in its place so that the 32 o2 sensor would be in the exhaust flow. $70. Or if your current o2s arent new just get new ones 33/34 ones like ali says. They're a different type (zirconia vs titania on the 32) but reportedly work fine.
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965371
I was, but I'm happy to be corrected
Well how far into the exhaust flow do they need to be? Anyone got a rough cost of the O2 sensors? 'Reportedly' worries me......Nothing is sure in the game of stuffing around with GTRs....
https://www.sau.com.au/forums/topic/298454-r34-gtr-dumps/#findComment-4965486
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
