Hey lads, joined a while ago and thought I would quicky Introduce myself.
Don’t own a Skyline but have a interest in them as well as many other cars, love the R32 GTR’s and really love the R35’s after going for a drive in one (like OMFG!!!)
Got one project on the go (28 Inter Pick Up) and one on hold (32 Ford) so you could say I’m a bit of a Hot Rodder.
Just joined to see what was happening on the development side of things with the R35’s so you might not see me posting much.
Anyway I’ll let you guys and girls get back to reading more interesting stuff. :rofl:
Cheers
Chris
https://www.sau.com.au/forums/topic/298480-hello/
hey man, welcome. got any pics of the 32 ford? i'm a bit of an early ford fan. my in-laws are rodders.
Got some somewhere, I should have pointed out I only have the rolling chassis right now.
Was planing a 3W Coupe.
I can't wait to get back into it to.
I'll get a couple of photos together and post them up, but it doesn't look like much. :rofl:
https://www.sau.com.au/forums/topic/298480-hello/#findComment-4965249
  • 4 months later...
If you build it ,it will skid.
Always wanted a rod, but a dirty rat rod, matte black and barely legal. Trying to convince the missus at the moment, I did have the go ahead but hesitated and now she thinks that we need something comfy for 2 adults and 3 kids which isn't to expensive to run.
ZD/F Fairlane on gas ?
https://www.sau.com.au/forums/topic/298480-hello/#findComment-5208085
Yeah I rock! :D
What "weird font"?
BTW can you get me another bourbon? :D
ok I couldnt see it on your laptop cos you were too far away, but it's totally partly in one font and then changes to a different one. Looks like the work of a gumby.
And I do believe you can get your own f**king bourbon!
:D
thanks again for your help today :cool:
https://www.sau.com.au/forums/topic/298480-hello/#findComment-5208286
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
