Hey lads, joined a while ago and thought I would quicky Introduce myself.
Don’t own a Skyline but have a interest in them as well as many other cars, love the R32 GTR’s and really love the R35’s after going for a drive in one (like OMFG!!!)
Got one project on the go (28 Inter Pick Up) and one on hold (32 Ford) so you could say I’m a bit of a Hot Rodder.
Just joined to see what was happening on the development side of things with the R35’s so you might not see me posting much.
Anyway I’ll let you guys and girls get back to reading more interesting stuff. :rofl:
Cheers
Chris
https://www.sau.com.au/forums/topic/298480-hello/
hey man, welcome. got any pics of the 32 ford? i'm a bit of an early ford fan. my in-laws are rodders.
Got some somewhere, I should have pointed out I only have the rolling chassis right now.
Was planing a 3W Coupe.
I can't wait to get back into it to.
I'll get a couple of photos together and post them up, but it doesn't look like much. :rofl:
https://www.sau.com.au/forums/topic/298480-hello/#findComment-4965249
  • 4 months later...
If you build it ,it will skid.
Always wanted a rod, but a dirty rat rod, matte black and barely legal. Trying to convince the missus at the moment, I did have the go ahead but hesitated and now she thinks that we need something comfy for 2 adults and 3 kids which isn't to expensive to run.
ZD/F Fairlane on gas ?
https://www.sau.com.au/forums/topic/298480-hello/#findComment-5208085
Yeah I rock! :D
What "weird font"?
BTW can you get me another bourbon? :D
ok I couldnt see it on your laptop cos you were too far away, but it's totally partly in one font and then changes to a different one. Looks like the work of a gumby.
And I do believe you can get your own f**king bourbon!
:D
thanks again for your help today :cool:
https://www.sau.com.au/forums/topic/298480-hello/#findComment-5208286
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
