Hi all had anyone here know or consider LPGing their RB25DE, coz I am what are the pros and cons of doing so, would it kill the engine quicker?
Some people is saying most likely there will be a power gain of 5% is it true? and what are the cost of LPGing a n/a R34?
Cheers :rofl:
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/
go and talk to a LPG conversion place for prices. as for performance, the amount you spend on it won't be very good bang for your buck. you could spend the money on other mods and gain way more power. and don't think you are going to save any money on fuel by doing it. maybe if you plan on keeping the car for 15 years and plan on doing LOTS of driving you might eventually see it pay for itself, but generally you won't. yes LPG is cheaper but you also have to use more of it to make the same power, so it sort of averages out.
here's a quick idea of what sort of savings it would have to have. if you put $50 worth of fuel in your car every week, that is $2600 a year on fuel. at that sort of rate it would take you 4 years to pay off the conversion
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4965269
My brother is running an R34 GT-V N/A on gas vapour injection. If your in melbourne hit up a place called AG Autogas which are located in lilydale. They did an awesome job. Car runs perfect and does not lose any power on gas. The car is soon going in for a Turbo conversion so dare i say one of the first Turbo r34's running on gas.
Not to mention $26 of gas to 400km
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4966071
Since LPG has higher octane - to help offset the power loss you should up the compression or get a turbo.
But you will not be saving any money on LPG (unless you do heaps of km on fwy/constant driving speeds) as you will need to burn more to get the same amount of energy as petrol for acceleration.
Conversion costs and LPG maintenance also need to be factored in too.
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4966198
that's ok but not great. if it was round town then it's good, but on the highway it's not great. i know it's a smaller car, but in the SSS pulsar i can get that sort of running costs/economy from highway driving and i didn't have to spend a few thousand dollars to do it. a few months back i had to take mum down to brisbane. 380km round trip (after work to make matters worse), over half the trip in 110kmh zone which makes it use that little bit more fuel than the 100kmh zone, probably at least 20 or 30km of driving through the centre of brissy and occasionally playing silly buggers. filled up before i left and when i got home. put in 98 octane (even though i normally run it on e10 and don't usually see much of a difference between the 2 in economy) and it cost me under $30 (think it was about $28).
so as i said, if that was highway economy, a few thousand dollars out of pocket and losing my boot space to save $2 when i fill up doesn't seem worth it, LOL
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4967328
Arent you comparing apples with oranges here? Compare it to any other R34 N/A out there running on petrol
$80 = Around 400-500km
$26 = Around 400km
you would need to fill up more than 3 times to get to the cost of 1 tank of petrol, and by then you would have travelled 1200km.
The gas system only cost him 2g out of his own pocket and the rest was covered by the rebate, so its wasnt all that expensive.
And yes that 400km was in town driving, no highway tests done yet on economy.
Have you seen the boot in the r34 sedan? lol He has the gas tank in there, a Massive amp and 2 x 12 inch subs in a big box and still has some room to spare.
Cheers
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4975737
whats the point of getting a skyline and putting it on gas :S? thats the stupidest thing ive heard
if the petrol price is to high for you then dont buy it
If thats the stupidest thing you have heard read the whistle thread... Clearly the point of putting it on gas is explained above if you have bothered to read the thread...
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4977067
i did read the thread, but if gas was so realiable and good to use, then why dont all imports have them then?
i guess this just pisses me off, cos my cousin brought a r33 gtst and sold it after like year and a half cos he complained it cost to much on petrol and wished it was on gas :S like when you buy these cars you know theyre going to eat fuel
https://www.sau.com.au/forums/topic/298481-lpging-rb25de/#findComment-4979532
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
