Okay wasnt running o2 sensor's previously and economy was so so was
around 320ish kW
power fc hks 2530's etc
running trust style (not sure they are genuine) long dump front pipes
was going to try to buy reducers today to refit the o2 sensors
only to find that the plugs I was using to block the hole on the dumps which were flush with the inside of the pipe
are nearly as long as the reach on the o2 sensors (see pic)
rough measurement I reckon I would end up with maybe 2-3 mm of sensor actually in the exhaust flow
not sure this will actually work previously the guy tuning the car said it probly wasnt worth running the o2 sensors anyway
what do you think will the sensors give acurate readings installed like that???
https://www.sau.com.au/forums/topic/298491-o2-sensors/
I modded my dumps so the o2 sensor was placed similarly to stock, so i didnt have to worry about if it would work or not.
I assume the dumps are still on the car, so maybe just try 33/34 o2s instead to make life easier.
If the guy has tuned the light load/cruise parts of the map to be 14.7 AFR then the o2 wont make much difference to economy.
https://www.sau.com.au/forums/topic/298491-o2-sensors/#findComment-4965392
