Hey all, I've got my turbo manifold wrapped in fibreglass heat wrap, its bin on for about a month now, it smoked a bit when I first started it up but was fine until yesterday.
I was reaching over my motor and knocked the oil line at the top of the turbo and oil came pissing out, all over the manifold (oh joy).
Now its smoking like f**k cos the heat's burning the oil off.
My question: Will this last long? I can see it taking a while to burn off, but do you guys think it'll stop smoking eventually?
Also, is it VERY dangerous? I can't see much risk of starting a fire, cos it's just smoking u know but wanna make sure...
Thanks.
https://www.sau.com.au/forums/topic/298492-exhaust-heat-wrap/
BUGGER!!!!
At least you know they wont rust now
I doubt just normal driving will start a fire but is hard to say really
cant offer ya much help maybe trying to clean it out a bit using like one
of those coin op carwash thingo's :rofl:
especially if ya got one near by?
Thanks for the replies...
cleaned everything just then, degreaser and a high pressure water hose (when the motor was cold of course) and it's smoking alot less now...
Took it for a spin around the block after it was all dry, and a bit of a boost when it was warm to get the heat into the manifold and turbo.
I'll keep an eye on it...
Ha. I painted my cam covers and changed the seals at the same time and somewhere along the line the rear half moon seal blew out and was pumping oil onto the exhaust. Just so happened to be that this was the same time i changed ecu's and we were doing a road tune as well so gave us a lot of grief when it started smoking hard. Fixed it straight away as defo not something to be left but the oil was on the heatwrapped dump and front pipe as well. It just smoked for a day or so and stopped.
Don't stress:)
Edited by JET-25L
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
