GCG Garret 550hp low mount ball bearing internal wastegate turbo
approx 5700km on it, braided water an oil turbo lines has seen 263rwkw on as low as 14.5 psi, can get past 300rwkw on 20psi and has on high boost setting. factory positioning on stock manifold
Custom split dump with screamer pipe leading to 3in front pipe that runs to the cat
Price Together: $1600
Nismo 555cc injectors (4250km approx)
Price: $700
Z32 Afm
Price: $200
TOTAL: $2500 for the lot!!!!
  • Replies 47
can you post some pics of the Garrett turbo,
you got receipts?
Hard to post pics on a low mount lol but i will later, its basically GCG's version of a rb25 hi flow, very discreet and yes i have reciepts
Edited by ON EDGE
ahh so it's still on the car lol, I'm only after the Turbo, are you willing to seperate?
yeah am willing to separate, however the dump/screamer is custom made specifically for the turbo so if your interested you should take that too, Pm me an offer on the turbo
can i please get some pics of the turbo setup and the nismo injectors pretty keen on those items thankyou :D
parts still fitted to the car, turbo fits in same stock position heat shield is off cos i needed to drill a hole through it so that the braided lines could fit
nismo injectors are the yellow ones
all in good condition
Are the injectors side mount, and have you got 4 or 6 (in other words, are they for an SR or an RB...) I want 4 for an SR.
side mount for RB, looking to sell everything together
  • 3 weeks later...
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
