How long is a piece of string unfortunately. ive heard of and seen $1000 dollar paint jobs through to $10000 paint jobs. Things in your favour: 1: New car so your current paint is a smooth base to lay new primer and paint over(hopefully) 2: Sounds like you want a single colour and without any candy or other expense adding extras.
You can save yourself money if you want to put in the effort of prepping the car for paint yourself, but in the end you get what you pay for in the finish. I would say ball park a couple of grand but hopefully people can shed some more light for you.
How much do paint jobs usually cost?
looking to get my white v35 changed to obisidian black
also comes down to how detailed you want it.. around inside of doors, etc.. lots of prep work.. best bet is go ask a few car sprayers.. also check their finished work before you go with them so you know what their quality is like
you always get what you pay for
Piece of string is best judgement haha
Depends on:
Quality of current paint
Whether you can do the prep work yourself
When it comes to painting do you just want the:
Exterior done
Exterior + Door jams
Exterior + Door jams + Boot + Engine Bay
Not sure what state you are based in, but places like Xxx Bodykits do full colour changes for $1900, average for exterior and door jams your looking around say $3000, then you can head into higher range quality paints as well like I'm getting DNA Paint so thats around 10,000 for exterior and door jams.
As craig and sean said, they can really vary depending on quality and how much you want painted.
I was looking to respray a clean r34 from white to black about a month ago.
If I was to strip the car and give them a shell, it would be 4-6k,
To let them strip the car I would expect to allow a further 1-2k.
These prices were from from DMD the Image (Brisbane).
I have seen their work and was quite pleased with it.
Obviously this is only my research, some people have had a car respray for a few hundred $$ + a carton of beer.
Cheers
how long is a peice of string.. seriously i can just pick a figure outta my head.. or you can go to a paint & panel and ask for a rough figure.. or call them.. not hard
just seeing if somebody has done it before and how much it costs, fair enough if you dont know, just dont reply with "how long is a piece of string" lol
Well actually matte black has become very popular over the last couple of years, so due to popularity its gone up in price so once again it can vary on the supplier.
My mate did it herself block back the car and used cans and it came out looking wicked...so you can give that a try and it'll be under $1000 haha :D
But professionally budget 5-6k
hey man if you want a paint job pm me and ill send you to my mate at 2sus if you want same colour it would prob cost you from 2 to 2500 and colour change without engine bay between 3500-5 have a look at some of his work he painted my last car and came out beautiful and im a fussy person
If you're referring to xxx bodykits in Melbourne... they start resprays at $1999, and they charge extra for colour change (doorjams etc).
But apparently they're work sux (looks like spray-can jobs). Or so I've heard from alot of their former customers.
If you want a respray...I'm guessing you want it to look good right? So if you're looking for something cheap, you might aswell get some VHT cans and do it yourself....coz it'll come out cr@p either way, but you'll save some money.
For a basic colour change, you're looking at $3000-$3500 minimum from a decent place. Pearls will cost you a few hundred extra atleast...Candy will set you back heaps because most spray-painters think they are a headache (ie. if they stuff up...it's much harder to fix it since the paint is translucent). I don't know what the heck obsidian black is....but you need to spend atleast $3000-3500, don't mess up your 35.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
