Well I was asked quite a few months ago to put my EVO VII in my mates wedding next January, Saturday the 16th.
When I was asked it had my old 'grenades' on and looked pretty tough, when i sold the skyline the 'grenades' went with it.
Needless to say it is now sporting the stockies and i would just prefer that it had some tough aftermarket wheels.
So basically what i'm hoping is if there is someone out there who would kindly lend me there 34 GTR wheels or something similair around the 18x9" (offsets and widths must be same all round) for a couple of days.
They will see no more than 150kms of rd and the car will be getting driven by a 50yr old man.
Cheers in advance.
https://www.sau.com.au/forums/topic/298567-hoping-for-a-favour/
Thanks for the offers so far guys, cause of the evo's constant AWD i really need the same widths and offsets all round.
18x9" +30 would be perfect (34GTR rims, work xd9's, volk te37's etc.)
Cheers again.
also so long as the rolling diameter is the same width and offset doesn't matter
I thought that we'd been through this before, lol
Here see if you can find two sizes that have the SAME rolling diameter. i bet you can't, say $5.
http://www.1010tires.com/tiresizecalculator.asp
i got 4 work emotion XD9's, 18x10 +18 with 275's on them if u get stuck
^ +1, 255 is a huge stretch on a 8.5" inch wheel imo unless the tyre is a semi slick... i havent done any calculations, but i estimate the rolling diameter difference to be anything from 0.25% to 1.5%
only a bees dick not enough to worry attessa
moodles did you even read it 255 is no stretch on a 8.5" rim :D
Actually you are completely right, I only had 13hrs sleep over the past 3 days... I think what I meant to say was its alittle big for the rim, sidewall wouldnt be as strong as the one on the 9" rim which would give slight difference to overall diameter...
Bees dick does make a difference with ATTESSA, I had Potenza G3's 225/50/R16's all around on my 32 GTR stockies and tore up my fronts at the track (if anyone remembers the private track day, I even considered running that tyre in reverse rotation... for about 30 seconds), I had Kumho KU36's on to replace those front ones in the exact same profile while keeping my rear G3's (tyre place only had 1 pair, and I couldn't drive around with outright defectable front tyres). The rears still have about 50% tread left... but the tread difference alone is enough to make my ATTESSA put power to the front wheels 24/7 (even if its just alittle bit)
should be careful with the 33's ATESSA Steve because of the preload on the clutch packs. With a difference in sidewall height of 10mm (5mm top and bottom) produces a 3% difference in rolling circumference which is 3km/h at 100km/h (obviously). This will produce premature wear on the clutch packs (especially on 33 and 34's) which as you will know are very expensive to replace. You might not have problems for a number of years but when R32GTR's are 20 years old now and they don't have problems with their clutch packs if you have problems after say 5 years then it has been caused by something, and as for your split as you would know when your gauge says 0 it's already at 10%.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
