Hi everyone,
I am thinking of rebuilding my r32gtr engine and am contemplating buying a used r33 GTR crank and used eagle rods (I am told these parts are in good order).
If I do use these what should I do before they go in the engine?
Crank - Inspected and Balanced & linished, anything else? Should it be cross drilled or is this not neccessary?
Conrods - Inspected, anything else?
Is it easy enough to check for cracks etc? Should I have these components cryo treated?
When the Crank is balanced & linished is then when it is measured up to confirm bearing size?
Any idea of typical prices for this type of work?
Sorry for all the questions but any guidence would be much appreciated.
Regards,
Thanks guys, sounds like new crank is the way to go. Would a new crank still need to be balanced or can it go straight in?
Also anyone have any thoghts on used h beam eagle rods? I think they have done around 20k.
Since nobody has asked the question yet, what sort of money were you looking at paying for the used crank and rods?
As has been said, a brand new BCNR33 crank can be had for ~$1100, and you can pickup Eagle Rods for ~$700
I wouldn't risk used parts for a rebuild in my car, period.
spen $50 getting the lot checked before commiting... easy solution. I am yet to find a decent GTR crank 2nd hand. Generally a reason the engie is apart. RB26's have a bad habit of cracking and bending with even a basic spun bearing.
The parts were only around $500 for the lot, thats why I was initially thinking about it, however now I am intent on buying a new crank.
As for the rods I would still imiagine that there would be some wear around the contact surface's with the crank and gudgeon pins.
Glad I asked the question, as I will stick to new parts. Thanks again everyone.
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
