Is this "family" car required for a "new" family or older family? I dunno about you guys but the amount of stuff I regularly need to cart around in the boot of my stag would never fit in a sedan (not without things getting broken).
You can survive with a sedan, but I reckon boot space is one of those things you never think you need, until you have it - and then you'll never go back.
Dead on mate. Could not agree more.
  • Replies 75
Since ive seen the price of stag wagons, i wish i had of got one...GC low kms under 10k...but it had to be turbo (to offset the ugly factor) which i think meant they wouldnt insure my girl until 25.... but yeah good value...
yeah it is for a new family so i expect a messy interior over time
Get an early model Caldina then - the trim in those things looks like a kid has ALREADY vomited on the seats...
haha good call >_< kinda like the patterned carpet they use in rsl clubs haha
oh god, not a TATA. they just go and buy parts (generally left overs) off other manufacturers and make them fit together until they resemble a car.
HAhahaha. True, But TATA are so big they bought Jaguar and Land Rover off Ford. They dont interfere with what the factories do, and fund them as required.
went through this dilemma myself last year, plaenty of good "family" cars floating around.
Mitsubishi Legnum TT
Mitsubishi Galant TT
Toyota Aristo TT
Nissan Stagea
only drama with these cars is, manuals are hard to come across if even an option.
Toyota Aristo TT
Nissan Stagea
plus I don't think the Aristo has the boot space for what he/she needs.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
