Hey,
I made a stainless steel water meth tank, and there is a lid that will be bolted down, and won't be undone exept for cleaning. Just wondering if anyone knows if insertion rubber will corrode with methanol..
I have also heard that once methanol is mixed with water it's shelf life dramatically reduces... How long can I leave it mixed together befor it goes stale.
Cheers
https://www.sau.com.au/forums/topic/298652-water-methanol/
Yes water is something you want to keep away from methanol. If you have a 44 gallon drum, keep it sealed at all times. Methanol turns to jelly when its stuffed and goes off. The last thing you want to be doing is putting jellified methanol thru your fuel system on your car. It will clog up everything.
In regards to the rubber, it will be ok providing there is constant flow of fuel and the car gets used. As soon as you dont drive the car for weeks, the methanol will turn to jelly and it will make the rubber go all powdery.
If you dont use the car for weeks, i suggest running the car until it runs out of fuel with the fuel pumps turned off, then blow out the fuel line system to clear everything out.
My only other thing about methanol, you cant do short cold starts all the time otherwise the oil goes milky. Always get it to running temperature before turning the car off. Dont just start it, move it 10 meters and then turn it off. It fills the sump up methanol making it go milky. Makes it appear like it has a blown head gasket when it hasnt. Thats just the way methanol is unfortunately.
Ive played with methanol engines plenty of times before in my speedway career. Its very good but very costly to run.
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4967663
Cool, i can understand doing that for street reasons. Running straight methanol does make the cars exhaust fumes real strong making your eyes water and nose sting. LOL Many times i remember that smell of methanol. Its one of a kind and its not like any other fuel to smell.
I have herd of people trying to mix methanol and water before but i have never seen it yet. Personally i would just use straight methanol and not bother mixing it. You would need some big kick ass injectors to run it on straight methanol.
I would be keen to know a bit more about water methanol injection. Gona have to do some research i think and learn a little more.
BTW apart from me babbling crap about methanol, i did answer the question in my first post. :laugh: If he is mixing the fuel, he is more than safe to use rubber. Just think, we use rubber fuel lines, yer... so it should be ok to use it for what he needs to do. :)
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968224
I think you are not grasping what the OP is talking about. This water/meth injection has nothing to do with his fuel system (mostly). He's injecting this atomized mixture of water/methanol into his intake air stream after the intercooler. It cools the intake charge and reduces your knock threshold letting you run more timing, more boost, and not have to use fuel to cool the combustion temps there by letting you run a bit "leaner".
http://www.snowperformance.net/faqs_type.php?type=gasoline
Read that.
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968252
Thanks for the replys.. Yeah I'm just wondering... It's not a daily car and I was wondering if one lot of methanol / water will last say 3 months in the tank. I might do some experiments and post results about the rubber
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968338
im well aware what he's using it for, but as for storing it methanol should not be stored with water. mix it as you need it.
I was directing that mostly at payback, however, I find it curious that they sell premixed water/meth (called boost juice) and it doesn't come with any type of experation, nor does the common everyday windshield washer fluid that is 40% meth 60% water. Hmmmm.....
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968632
If you can find out exactly what sort of rubber the 'insertion rubber' is (i.e EPDM, SBR or natural etc) look up a chemical compatibility chart and check it against methanol?
AFAIK, EPDM is fine with methanol. EPDM is fairly common, used for lots of o-rings etc.
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968726
Read that.
Cheers for the link. That was very helpful explaining about mixed methanol injection as a boost cooler. Interesting...
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968874
No problem. Pretty crazy stuff the first time you read about it, isn't it? Who'd have thought injecting a meth/water mixture would help performance? There is actually a pretty long history of at least water injection going back to even before WWII believe it or not.
https://www.sau.com.au/forums/topic/298652-water-methanol/#findComment-4968971
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
