THE ENGINE PARTS AND SUSPENSION ARE WORTH OVER 6500$,U ARE BASICALLY GETTING THE SHELL FOR FREE AND THEN SOME
FOUND A CAR THAT I WANT SO THIS HAS TO GO,PAY 7,000$ AND ILL CHUCK IN A T67 TURBO WITH TURBOSMART PROGATE
the laurel was imported from japan thru a wrecker, it was a drivable car, they had to remove the motor and trans to allow importation. was rb20e and auto.
chassi has done 92000kms,
The rb25de that was sourced was fitted to a torana and come with bellhousing to suit toyota gearbox (w58) and the haltech - (that was brand new still in box). fitted twin turbos , manifolds and all supporting oil water lines from r32 gtr which had had r33 turbos fitted, modded the manifolds to allow fitment to rb25 head. has fitted rb26 injectors, feul rail, regulator and moddified inlet plenum to forward facing item, also utilising velocity stacks on runners. It has toyota w58 box with custom 1 piece tail shaft. Welded diff. rb26 valve springs from performance springs( which are 30% heavy seat pressure that standard rb26) also had clutch slipping issues with brass button clutch that came with motor so this has just been replaced with extreme motorsport item, rated to 300rwkw. short description, will list all items fitted. power = 232rwkr@14psi. If any issues arise with rb25 short block it is very simple to add rb30 under head and associated hardware to make a rb30dett.
The body of laurel is overall good, no rust. The roof has some scraps and small dent on left side due to damage done while being loaded into container.
its a track only car!!!
Located Welland, S.a
Am chassing $9,000 ono!!!!! (make an offer!!!!!)................NOW 6500$ OMG ULEH
whats fitted to c33:
custom plenum - velocity stacks used
r33 gtr turbos, manifolds etc
custom ali intercooler pipe work and intercooler in front of radiator - minimal cutting to fit and short pipe work
BOV
2l catch can
rb26 valve springs - new
32mm copper cored radiator with aluminium fins - better cooling than cheap thick ali radiators
twin au falcon thermo and shroud setup with twin relay wiring
rb26 injectors, feul rail and regulator
new spark plugs gapped to 0.7
new power steer belt
new battery
new walbro 255lb/h in tank pump
new twin air filters
haltech e6k comes with old acer laptop and serial cable for tunning as haltech is older model and uses DOS
new extreme motorsport clutch just purchased and fitted cost $930
turbosmart manual boost controller
toyota w58 gear box with rod shop belhousing
new clutch master and slave cylinders
r33 clutch pedal box and pedal
exhaust is twin 2 1/2" off std dumps then merge under passenger seat to 1 3" and exits infront of left rear wheel
boost gauge,water tep and oil pressure guages mounted in custom ali centre consol
custom hydro hand brake
sports steering wheel and boss
sparco fixed back seat mounted to super low r33 sliding rail - standard passengers seat.
fully stripped interior except for door skins and top half dash.
all windows operational ( wern't when i got it)
cusco front coil overs with camber adjustment and spring adjustment
JIC rear coil overs - spring adjustment
Adjustable front castor rods
adjustable rear camber, toe and traction rods
5 stud conversion- just jap front hubs, r33 rear hubs - std brakes retained
welded r200 diff
R32 wheels with spacers to fill gaurds
any swaps etc considered..
more pics available on request
thanks for looking.
Contact sean on 0401823220
Get a tune and drift it......
hey mate couple quick questions, its running standard brakes yeh? how well do they hold up or would i be looking at getting slotted rotors etc? im from nsw, i may be able to arrange a form of transport if i were interested but not 100% sure so is there any forms of transport you would be able to provide for the car to nsw (id cover all expenses) thirdly would you be able to post a couple more photos? lastly you mentioned it would make a good drift car after a tune.. so was the 232rwkw dyno reading from when the car was tuned or how it currently runs?
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
