Rear Speakers Keep Melting
Looks decent, did you need to remove the dash? Tempting, but the effort and time I cbf. -
Took some pics, excuse the dirty footprints need to give it a clean after I finish the sound system haha https://ibb.co/Y79M6btJ https://ibb.co/4w86zShg https://ibb.co/ccMPMtDx
By Red Sky II · Posted
Hi I am looking at doing the same so was wondering whether you went ahead with the replacement. If so, who did you use, what fascia kit did you get and approximately how much did it cost? Cheers -
I can't edit my original post, but I've updated my tables to be split into two as it was getting a bit OTT having a single huge list. This now includes Turbosmart turbos - the first list is "entry level", or up to 68mm. The second is "for those who like to party" and starts at 62mm.
Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
