Hey all its time to sell my car, looking at to get a home loan and need some funds.
It’s a 98 sti type RA reshelled in a my95 body. (Paperwork available)
Steel mica blue
130, xxxx kms
SPECS: driveline and handling
Motor: 98 EJ20 J-Spec (STI type RA)
2.3Litre Stocker motor kit
Fully forged internals (forged crankshaft, rods and pistons),
[Engine was built by previous owner]
Motor had done aprox 30,000kms since built] Motor Runs perfectly.... any tests welcomed
Always service every 5000kms by me and always used ULX-110 oil
MOTEC racespecs computer (tuned by Shaun at boostworx)
550cc injectors,
NGK Spark Plugs
Walbro fuel pump
Blitz pod filter
Turbo smart adjustable blow off valve
Hybrid front mount intercooler
Spitfire coil packs
TD04 turbo (stock turbo)
3” turbo back exhaust (no cat)
After market dump pipe
Strengthened first and second gears.
Exedy heavy duty clutch
APEXI adjustable suspension all round
Front slotted brake discs
Adjustable sway bar
Apexi AVCR (black) boost controller
Apexi boost gauge
HKS turbo timer
17 inch speed line gold rims 70% tread all round (few gutter marks)
ITERIOR:
Nardi steering wheel
Leather seat front and back
Alpine DVA-96ie head unit. DVD receiver
Alpine V12 amp
Twin kickers sub (custom box)
Kicker amp for speakers
DLS speakers
Clarion TV
EXTERIOR:
Carbon fibre bonnet
Angel eyes headlights
Smoked front indicators
Smoked side indicators(will be included in sale, havnt had the chance to put them on hence the orange ones in the photo)
Rear altezza carbon fibre look rear lights
Type D front bar?? From viva garage
Fog lights removed
Dark tinted windows
STI wing
Fully debadged
Car is currently running at 180kw at the wheels with stock turbo,
just whack on a bigger turbo it will easily make 230-250 kilowatts at the wheels no problems.
Engine can probably handle up to 300kw
Price $17,500 o.n.o
0424177447
Please call if you would like to have a look. No timewasters and tyre kickers please
Attached thumbnail(s)
https://www.sau.com.au/forums/topic/298704-wrx-98-sti-type-ra-sa-adelaide/
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
