  • Replies 46
there are 4 runs each differnt colour of pattern of line. The upward hill lines are the max power. The bottomw jagged lines are a/f ratios.
an ideal afr on a turbo car is 12:1
meaning 12 paers air to one part fuel.
on a na car its about 14.8:1 me thinks
Question: Why the hell on your dyno graph do u run real lean when it gets to red line around 6500-7000rpm???? Dangerous?
Enrico: Not sure why the graph runs lean at the end... The car was only run to 6500-6700 before the dyno operator backed off... Looking at the graph here, the lean AFR's aren't under power, so I assumed this was just the AFR's going into decelleration mode?
Even so, nothing goes over 12.5 which isn't "too" bad.
To be honest, I don't think the dyno operator really knew what he was doing. I certainly wont be going back to that establishment...
As for 2nd gear? Mines auto... Trying to keep the auto in 3rd or 4th when flooring it from low revs is impossible. Kickdown takes over and your in 2nd gear again :D
Noones ever successfully explained to me why dyno runs need to be done in a certain gear anyway... If it's to do with the ratios, how can we compare between say, a bombadore and an r33 on the dyno... Even if they both run in 4th (1:1), the diff ratios are different anyway...
Thoughts?
Looks like he did a 2nd gear run too. the fuel leaning out is taking foot off pedal.
strutto, if that was fully stock (which it appears) that dyno shows a nice healthy engine - ripe for the modding:)
hippy, it appears to me that street tuning is something that takes a bit of experience. Not too many tuners around these days that do it anymore, infact I dare you to tell me the name of one in Adelaide:) The road side of things is good for off boost and driveability, but you need to get the car on a dyno for a final trim and to make sure everything is ok.
Also, just do be careful you dont go crazy and pull too much fuel, just because you dont have a huge amount of mods, doenst mean you cant smash ring lands if you pull too much fuel.
Well the reason people say to do the run in 1:1 gear is that power is a function of torque and rpm.
Imangine if you use a lower gear, the mechanical advantage will be higher, therefore the torque will be higher, giving a higher power figure.
That is until you get to peak power, which will read the same, as the wheel speed is alot slower for the same rpm (as in a higher gear) but as the torque is higher due to mechanical advantage, the difference is cancelled out.
My understanding anyways, and I do have the 3rd gear and 4th gear dynos with the same power to prove the theory:)
Hmm, well if you have got a 3" from front pipe back, you 'should' be getting more than 5-6psi. Stock boost is 5psi to 5000rpm then 7 psi to redline, you should have a couple of extra pounds with cat back..
dynos not bad though, I didnt read the previous posts and didnt realise it was an auto till after I posted:)
This was done on 5-6psi...  (No factory bleed, DIY bleed closed).
Yea, I have disabled the factory bleed and use my own incabin bleed. This was closed during the dyno runs. Factory wastegate opens at 5psi I believe. The extra 1psi or so up high is due to the less restrictive exhaust I reckon...
interestingly enough, my safc was used to richen the mixtures up top....
It did 5 runs on the dyno in 4th gear and by richening the mixtures (+9%)from about 5k onward (75%throttle) I was able to gain a healthy 17rwkw and totally eliminate pinging. The car has a much fatter power curve and feels 100% better on the road. Plus I have the peace of mind that it isn't pinging and is safe to run at 12psi.. I'd go dyno tuning over road tuning unless you really know what you're doing.
hippy u r gonna fark your engine up man.
it only takes about 30mins for someone that knows what they are doing to tun your car on the dyno!!
also fyi i could get my gfriends old 1.3 litre mazda 323 to wheel spin in 1st gear, so spinning the 33 in first is no biggie! :P
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
