Hey Guys
I have an rb25/30 in my 33 series 1. It has 850 sards, a gt35r and 45mm external gate (plumbed into exhaust).
I am located in Townsville
Does anyone know someone up here that would give me a mod plate? I'm not ONLY after some dodgy up cash job (although that would be nice). I am happy to go to a business and do it all properly I was just wondering if anyone up this way has gotten mod plates, if so what were they for, how much did it cost and who did you get it/them through? ESPECIALLY after anyone else who has done the twin cam 3L legally.
Cheers
Lukas
https://www.sau.com.au/forums/topic/298718-mod-plates/
Lindsay Stone ??
Living Stone Automotive
Lindsay Stone
Telephone: (07)47708807
Fascimile: (07)47748807
E-Mail: [email protected]
Have you personally dealt with him? Not saying he's not good or anything Im just curious :D
https://www.sau.com.au/forums/topic/298718-mod-plates/#findComment-4968892
He's the guy i told you about. Mod plated dads car. One of the nicest guys you'll meet, just ring him up and see what he says.
Ahhhh yeh I thought the name sounded familiar. I take it he doesnt do weekends? I have many phone calls to make when I get home
Cheers man
https://www.sau.com.au/forums/topic/298718-mod-plates/#findComment-4969064
Just a bit of info for anyone else who is looking into getting mod plates for their car. I just rang up the engineer and he said that they can easily do rb25/30 here in Queensland. Just have to make sure there is 20mm clearance or hoses etc so there is no rubbing and that the car meets the emissions standard. The engineers do all of the emissions testing in house. The transport department has nothing to do with it. I phoned Queensland transport and the lady on the phone said that they do not do compulsory emissions testing to check your vehicles emissions, it is all up to the engineer who is inspecting the car and issuing the plate/certificate.
I will obviously keep this thread updated with my progress on actually getting my modification plate. I now just need to look into getting a nice new cat to help clean up those exhaust gasses and look into fitting a carbon canister and getting the envirotune :P
On a side not anyone who has a carbon canister with lines preferably that they want to get rid of Im all ears :D
https://www.sau.com.au/forums/topic/298718-mod-plates/#findComment-4969431
Lol looks like your going to have to swing by again, i got one :D
Maybe you can swing buy and show me your new toy!..........ok that just sounded way too dirty when i read it out loud. Im sure you know what I mean. How much you want for it :blink:
https://www.sau.com.au/forums/topic/298718-mod-plates/#findComment-4969580
Update on getting my car legal:
I spoke to the tuners today. They said that I should leave on the stock cat, connect up the carbon canister and put in the stock injectors and have a very very mild tune for when I go in for emissions. Dont know how that will go seeing as I have a 45mm wastegate with a 20psi spring. Maybe I could just take out the springs all together :blink:
Does anyone have any other suggestions as for what I should do?
I would love to try bribing but I doubt it will work :down:
https://www.sau.com.au/forums/topic/298718-mod-plates/#findComment-4971571
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
